Air Conditioning
Old Apr 8, 2003 | 02:33 PM
jonoknut's Avatar
Default Air Conditioning
Its starting to warm up here in arizona. I havent used my air conditioner in probably 4 or 5 months, but as you can imagine summers here are horrible, and it just sucks without air conditioning. I tried it a week ago for a minute or two with no luck, it was blowing hot air nice and strong. I said eh, and moved on. I heard that it needs 5 minutes to cool down, so I tried, but nothing. I had my air on for a good 15 minutes coming home with no change in temperature. I;m not sure what to do i looked i the book and made sure i had everything right and i did. The manual also mentions you should always take your air conditioner to a dealer. Well i know that will be expensive becuase either way they will find something wrong. Is there somewhere i can check my freon level, or whatever they use? or do some kind of test of any sort?? lemme know, thats a lot
jon
Old Apr 8, 2003 | 02:53 PM
YumVTEC's Avatar
Default Re: Air Conditioning (jonoknut)
get a ac recharge kit at pep boys/checker/auto zone
Old Apr 8, 2003 | 02:57 PM
jonoknut's Avatar
Default Re: Air Conditioning (YumVTEC)
how easy is it to do? how much are they?
Old Apr 8, 2003 | 03:02 PM
97civicdx's Avatar
the recharge kits for 134a are usually around 20 to 30 bucks. That includes the oil and the 134a in a can. How old is your car when was the last time anything was done to your a/c unit.
Perhaps it might be better if you take it to a ca shop and pay the to totally evacuate the system, check for leaks, and recharge.
Old Apr 8, 2003 | 03:06 PM
jonoknut's Avatar
Default Re: Air Conditioning (97civicdx)
my car is a 95 gs-r. I have had it since september, and the air worked fine for the few weeks that i used it. I havent done any work to the air, so im not sure whne the last time was
Old Apr 8, 2003 | 04:09 PM
97civicdx's Avatar
If I were you, id just take it to a shop, and do all the stuff i posted above. That way, u know the refrigerant is all new, and u will be shivering in 40 degree a/c. At least thats what my toyota tacoma xcab hits. I never recharged it yet but its still freezing. Yours might be already dead or might have a leak. Take it and get it done right the first time.
Old Apr 8, 2003 | 04:11 PM
b0wti's Avatar
my 96 gsr does the same thing, took it in, all it needs is some freeon, lowest quote i got for free on charge, was 90 bucks, seems worth it to me.
Old Apr 8, 2003 | 06:39 PM
jonoknut's Avatar
Default Re: Air Conditioning (b0wti)
i just asked this guy that works behind my work at the firestone, and he said 120 bucks. i dunno if its even worth it. he did this thing i thoguht was weird, a test where he unplugged something to do with the air conditiong, and inserted a paperclip to it to close the circuit or sumthing, and then i heard the engine go faster, like i was to turn the air on, and then he undid it after ten seconds and it went back to normal, it sounded like the air was gonna work or something then. Does anyone know what that test is and what it shows? thanks
jon
Old Apr 9, 2003 | 04:34 AM
JimBlake's Avatar
Could be a bunch of things, but here's my guess...
There's a low-pressure switch in the AC system; so if the refrigerant pressure is low, it prevents it from running. Maybe he jumpered that switch to see if the compressor would run. Seeing that it did, he probably said that you were just low on refrigerant.
Old Apr 9, 2003 | 05:07 AM
LSintegra's Avatar
Default Re: Air Conditioning (JimBlake)
i had the same problem u are having awhile ago. for me however my cai was rubbing against the ac lines in the engine bay and it broke the line. i took it to a shop and they welded it back together. so if u have an intake check under it and see if anything is rubbing against it.
pippin65
Honda Civic (2006 - 2015)
17
May 10, 2008 06:33 PM
chuckylee97
Jan 27, 2007 02:21 AM
hondaracin24
Feb 27, 2006 06:10 PM
B18C1 '96 Coupe
10
Mar 9, 2003 12:01 PM
