advance timing
Old May 13, 2004 | 10:06 PM
hmongboyLS's Avatar
Default advance timing
so what's the pro's and con's on advance timing... i was thinking of doing it but wasn't really sure if i should go for it... doesn't matter which motor non-vtec or v-tec i just want to get your .02 cents
Old May 13, 2004 | 10:10 PM
Kendall's Avatar
Based on several sets of dyno charts I've seen, advancing the timing will increase power throughout the power band, but it will also cause you to peak out a bit sooner, depening upon a few factors. Peak numbers can sometimes suffer, however the more powerful torque curve will easily make up for it in most circumstances. I suggest you have timing set on a dyno.
Old May 13, 2004 | 10:19 PM
tilt's Avatar
Default Re: advance timing (hmongboyLS)
kendall pretty much summed it up. it wont hurt to play around with it as long as you keep it within reason (~2degrees), but a dyno will let you know what is exactly going on and what degree works best for your setup.
the negative is if you advance too much you can start pinging/detonating.
Old May 13, 2004 | 11:23 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: advance timing (tilt)
BTW if you decide to play with your timing, please have 91 octane in your tank
Sack Master's Avatar
Don't you guys think taking your car(and a car thats probably pretty stock) to a dyno to get your timing done is a bit extreme? I know I wouldn't pay $50 for a gain of 1/3 hp.
Old May 13, 2004 | 11:24 PM
Default Re: advance timing (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Don't you guys think taking your car to a dyno to get your timing done is a bit extreme?</TD></TR></TABLE>
I agree, i wouldnt go that far unless i had more engine work done.
Old May 13, 2004 | 11:36 PM
hmongboyLS's Avatar
Default Re: advance timing (ThE bEe GuY)
true... i just wanted to find info on it... cause there's some guys around town that has i/h/e and they advance their timing
Mike Lowwryyy
Engine Management and Tuning
Jul 12, 2012 08:50 AM
S-=N=-A-=K=-E
Oct 19, 2006 02:25 PM
jmal1919
Jun 1, 2005 12:39 PM
cnycivic
Jun 25, 2003 09:44 PM
brownman72000
Jun 8, 2002 07:33 AM
