adjusting timing
Old Oct 20, 2006 | 07:50 PM
skata89's Avatar
Default adjusting timing
Well im looking at advancing my timing up to 18 but I read somewhere that your idle has to be at 750 +/- . My idle is around 1000 and 900. Is it still safe to adjust it when its like that? Ive searched and I didnt really find my answer so please no flaming.
Old Oct 21, 2006 | 08:19 AM
skata89's Avatar
bump
Old Oct 21, 2006 | 08:25 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: adjusting timing (skata89)
Why was the idle so high? Were all of the accessories turned off? Was the car fully warm?
Old Oct 21, 2006 | 09:27 AM
skata89's Avatar
the idle is high bc it seems to run better when its around 900. anything lower it seems to struggle.
Old Oct 21, 2006 | 10:03 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (skata89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 &raquo;</TD></TR><TR><TD CLASS="quote">the idle is high bc it seems to run better when its around 900. anything lower it seems to struggle.</TD></TR></TABLE>
Yes, but why is it high? The ECU should be targeting 750 RPM by controlling the IACV. Is your ECU modified or is the idle adjustment screw wide open?
Old Oct 22, 2006 | 05:23 AM
skata89's Avatar
well i adjusted it by removing the iacv and my ecu is a chipped p28
Old Oct 22, 2006 | 01:03 PM
Dogginator's Avatar
Daisy... Daisy...
Can you adjust it to 750 for setting the timing? Why did you remove the IACV? Couldn't you have programmed the ECU to idle higher? I'm surprised that you don't throw a CEL for having no IACV.
nekoabandoned
Feb 16, 2009 10:13 AM
b00stedbyFastrax
May 4, 2008 07:17 PM
civickiller
Feb 15, 2007 12:38 AM
guywitaDA
Dec 29, 2005 11:05 AM
B16CRXT
Jul 19, 2004 11:06 AM
