acceleration problems!!
Old Feb 22, 2006 | 08:06 PM
import_king20's Avatar
Default acceleration problems!!
car accels fine...but when i get to about 6k in 3rd gear car quits accelerating and check engine light comes on...then when i turn the car off for about 30 min and turn it back on the check engine light is off...HELP!!!
Old Feb 25, 2006 | 11:30 AM
Default Re: acceleration problems!! (import_king20)
HEEEEEEEEELLLPPP!!!!!!!
Old Feb 25, 2006 | 12:05 PM
Dogginator's Avatar
Daisy... Daisy...
We do not know what car or engine you have. Can I assume this is a B18C1? Try this and report the CELS:
https://honda-tech.com/zerothread?id=978933
Old Feb 27, 2006 | 09:51 PM
Default Re: acceleration problems!! (Dogginator)
yes i have a 98 gsr. i just got an ITR LSD trnny put in but i had the problem even b4 i got the tranny.
Old Feb 27, 2006 | 10:02 PM
Spectrum24x's Avatar
Vehicle speed sensor?
Is it at a certain RPM or a MPH that the CEL comes on?
Old Feb 27, 2006 | 10:10 PM
e-honda's Avatar
do what dogginator says. (he seems to be one of the most knowledgeable ppl in the integra sec. or in h-t in general for that matter. thumbsup dogginator!
Old Feb 27, 2006 | 10:18 PM
EF-EF's Avatar
did you get a new throttle body?if so I had the same prob cause when I changed it out I didn't recalibrate the tps sensor and it would do that..
Old Feb 28, 2006 | 04:49 PM
Default Re: acceleration problems!! (Spectrum24x)
its usually around 3rd gear at 6-6.5k RPM
Old Feb 28, 2006 | 06:13 PM
Dogginator's Avatar
Daisy... Daisy...
We can keep speculating or you can pull the CEL codes and correctly address the issue.
Old Mar 3, 2006 | 04:08 AM
as soon as i turn the car off the check engine light doesnt come back on so i cant do as u recommended!...today i was in 5th gear at about 65 mph..i went to downshift to 4th to pass a car and it wouldnt let me accelerate again..one again the check engine light came on....
Old Mar 3, 2006 | 04:46 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import_king20 &raquo;</TD></TR><TR><TD CLASS="quote">as soon as i turn the car off the check engine light doesnt come back on so i cant do as u recommended!...today i was in 5th gear at about 65 mph..i went to downshift to 4th to pass a car and it wouldnt let me accelerate again..one again the check engine light came on....</TD></TR></TABLE>
The computer will store the codes. You can retrieve them with the recommended procedure.
Old Mar 3, 2006 | 03:01 PM
HMMM...weird!...i used the recommended procedure but the check CEL stays lit up constantly...no flashes or blinks...HELP!!
Old Mar 3, 2006 | 03:54 PM
Dogginator's Avatar
Daisy... Daisy...
Perhaps an auto parts store can check for stored codes. They will usually do this for free.
Old Mar 3, 2006 | 04:14 PM
integra3586's Avatar
go to autozone, theyll check em for free
Old Mar 3, 2006 | 04:55 PM
even if the check engine light is off at the moment?
Old Mar 3, 2006 | 04:57 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import_king20 &raquo;</TD></TR><TR><TD CLASS="quote">even if the check engine light is off at the moment?</TD></TR></TABLE>
Yes, most codes are stored.
Old Mar 6, 2006 | 12:26 PM
i stopped by auto zone today and they hooked up to my car...and there were no codes stored...it sux not knowing what the prob is cuz u cant fix it!!! HELLLP
Old Mar 6, 2006 | 12:50 PM
Dogginator's Avatar
Daisy... Daisy...
Check your oil level. Perhaps your car is dropping out of VTEC.
Old Mar 6, 2006 | 01:20 PM
onnoff7's Avatar
same thing happned to my car before. got it checked and it was vss but it was also other things. vehicle speed sensor
eg6madness
Honda Fit
39
Dec 9, 2009 09:18 PM
alanz
Jul 18, 2006 10:16 AM
import_king20
Apr 14, 2006 04:23 PM
vietboycuhz
Oct 21, 2005 09:27 AM
waijsR
Oct 30, 2003 01:43 AM
