something wrong with vtec?
Old Apr 12, 2006 | 05:08 PM
import_king20's Avatar
Default something wrong with vtec?
ok...so i have a 98 gsr w/ ITR LSD tranny. heres the situation... i can hit redline ***** to the wall 1st through 3 ...then when 4th gear hits 5000 rpm the check engine light pops on, it quits accelerating and this DISGUSTING sound that comes from the motor followed by the smell of burnt oil. i shift to fifth it accels fine until 5000. keep in mind the CEL is still on. i come to a complete stop and start driving again and now at 5000 rpm in every gear it does the same thing. if i turn the car off for a second (literally) and turn it back on the CEL goes off and it drives fine until forth gear at 5000 rpms...same thing al;l over again...i took it to autozone cuz i was told that ecu stores codes..well i turn my car off they hook up the gadget and it says no codes reported meaning they cant tell me nothing. somebody PLZZZZZZZZZZZZ help me!!!! by the way i already tried resetin the ecu...didnt work.
Old Apr 12, 2006 | 05:10 PM
Lan's Avatar
Lan
Default Re: something wrong with vtec? (import_king20)
Check the code yourself... Do you know how to read them? There is a 2 prong connector call the SCS connector hiding under the dash where the ECU is. Pull it out pull a paper clip in both ends to connect them together and check the amount of blinks you get.... Long blinks =10 short ones =1
Old Apr 12, 2006 | 05:14 PM
Dogginator's Avatar
Daisy... Daisy...
The Integra Forum FAQ has a link with instructions to check CELs.
****INTEGRA FORUM FAQ****
Old Apr 12, 2006 | 06:36 PM
geezer_187's Avatar
Default Re: something wrong with vtec? (Dogginator)
If its a 98 then its OBDII, you should have a data link connector under the dash on either the drivers or most likely the passenger side. Take it to autozone or your acura dealer and they can pull the code for you. I think that you only have to use the paper clip (or jumper wire) method if it is OBDI with no data link. I have an OBDI 95 gsr, and thats what I have to do. Just my .02
Old Apr 12, 2006 | 07:51 PM
1337whp's Avatar
Default Re: something wrong with vtec? (geezer_187)
hows your oil level? when was last time it was changed
Old Apr 12, 2006 | 11:58 PM
Default Re: something wrong with vtec? (Lan)
dont uhave to turn the car off b4 u use a paper clip and then turn it back to the on position?...cuz as soon as my car is turned off...the check engine light is off.
Old Apr 13, 2006 | 06:18 AM
pompom's Avatar
it sounds like your oil pressure or level. mine did the same thing in the same gear. i topped it off and it ran fine. try putting a qaurt in and report back...
Old Apr 13, 2006 | 07:08 PM
can u check it while the car in on?
Old Apr 13, 2006 | 08:22 PM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pompom &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your oil pressure or level. mine did the same thing in the same gear. i topped it off and it ran fine. try putting a qaurt in and report back...</TD></TR></TABLE>How about telling him to check the oil level before you just tell this kid to add a quart? It might have more than enough oil in it already.
Old Apr 13, 2006 | 08:31 PM
gsr dood's Avatar
Default Re: something wrong with vtec? (Sack Master)
yes if the code goes away u should check wen the car is on....i did that for my knock sensr CEL ....it would turn off wen i turned my car on. just check with the car on and cel on
Old Apr 14, 2006 | 04:23 PM
Default Re: something wrong with vtec? (pompom)
ok so i got the cose...22...vtec pressure valve...expensive to replace or can i do it myself...also where is it located?
Killspeed93
Sep 21, 2011 08:12 AM
hulsey
Honda Civic (2001 - 2005)
Sep 3, 2010 11:51 AM
Mtwostwo
Jun 22, 2010 03:00 PM
import_king20
Mar 6, 2006 01:20 PM
Dd95Gsr
Jul 24, 2002 02:00 AM
