AC issues
Old Aug 30, 2010 | 10:07 PM
1badcrx's Avatar
Default AC issues
So over the last few days I have noticed that my air has stopped blowing as hard. Today after about 15 minutes in the car it slowed to almost not blowing at all. I could hear the motor spinning but it was clicking a little, I turned the air off and back on hoping that would solve the issue... and when i turned it back on it stopped all together. I let the car sit for about 8-9 hours while working and came out and it started blowing fine, then slowly stopped... Any ideas? the blower motor, resistor? Any info appreciated
Old Aug 31, 2010 | 05:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: AC issues
Will it "slow down" when set at any speed?
It sounds like a connection problem, to eliminate the blower motor as the problem make a temporary ground for it, using a jumper lead ground one end to cars chassis, [any ground point will work] stuff the other end into the ground side, [blue/black] of blower motor power plug, blower should blow at full speed.
If blower does not slow down the problem is most likely the blower resistor. 94
Old Aug 31, 2010 | 10:18 AM
1badcrx's Avatar
Yes, it slows at any speed, which led me to believe the resistor was going out... but I'm not certain. And thanks for the input on checking the motor! Any more insight is greatly appreciated.
Old Aug 31, 2010 | 07:13 PM
1badcrx's Avatar
ttt
Old Aug 31, 2010 | 10:16 PM
vtaker's Avatar
After reading the manual, your assessment sounds about right. The resistor is likely toast, but test it first to make sure.
goherd1549
Honda CR-V & Element
Jan 23, 2018 02:06 PM
honda305
Sep 16, 2013 07:27 PM
adand001
Jun 8, 2008 01:23 PM
93_teg_CT
Oct 26, 2006 11:56 AM
mymeatb18"
Jun 10, 2006 03:11 PM
