Ac doesn't blow at all.
Old Sep 15, 2013 | 09:00 PM
honda305's Avatar
Default Ac doesn't blow at all.
Got a 2003 civic and the ac just stopped blowing air in all settings. Anyone know where I can start tackling this problem?
Old Sep 16, 2013 | 12:52 AM
holmesnmanny's Avatar
Default Re: Ac doesn't blow at all.
check for leaks
Old Sep 16, 2013 | 03:08 AM
jmarshall098's Avatar
You can refer http://www.wikihow.com/Fix-Your-Car's-Air-Conditioner to make the Air Conditioning work again.
Old Sep 16, 2013 | 07:03 AM
fcm's Avatar
fcm
Old Fart
Do you mean the blower has stopped working, [no air from vents with heat or A/C? 94
Old Sep 16, 2013 | 07:43 AM
honda305's Avatar
correct.
Old Sep 16, 2013 | 04:53 PM
fcm's Avatar
fcm
Old Fart
So the first thing to do is test for power at the blower motor, [ign. switch on] should be a blue/white lead, if that is good, [you have power] use a jumper lead to supply a ground directly to the other lead, should be a blue/black lead, if that works, replace the blower resistor. 94
Old Sep 16, 2013 | 07:27 PM
honda305's Avatar
Ended up being the blower motor and resistor. Thanks
triet43
Aug 10, 2014 06:09 AM
BumbleBee Tuna
Honda Civic (2001 - 2005)
May 19, 2008 09:03 PM
digital sol
Aug 6, 2007 04:34 PM
hollot1p
Jul 15, 2006 06:29 PM
rudeman85
Apr 23, 2005 09:37 PM
