abs problem again. help
I had my ABS computer changed in 99/00. Now I have a little problem with it again. When I start the car, sometimes the ABS light would remain on sometimes it would go off like normally when you start the car. What could be the problem?
First thing you should do is check to see what code your ABS system is throwing. You can check the code by jumping the service connector. The service connector is a green plug located on the passenger side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraLSSE95 »</TD></TR><TR><TD CLASS="quote">Could it be that the ABS connectors are loose? if yes, where can I locate the connectors to check? what color are they?</TD></TR></TABLE>Yes, it could be a loose connector for a wheel sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote">You can check the code by jumping the service connector. The service connector is a green plug located on the passenger side.</TD></TR></TABLE>THIS is the connector you want FIRST. Why screw around with connectors if you don't know what code it's throwing??
jordan_civic
Aug 31, 2007 07:36 PM
