abs problem
Old Oct 1, 2005 | 10:27 AM
accordredliner's Avatar
* B A N N E D *
Default abs problem
my abs motor started to buzz for about 40 sec,stops and the abs light went on. This had happened before and I fixed it by adding fluid to the abs module. I did the same this time but when I start the car the abs doesn't seem to buzz to pressurize the system. Is there a reset procedure that I have to do? I checked all the abs fuses in the engine compartment already.
Also, how do u get the error code?
Old Oct 1, 2005 | 10:44 AM
Chiovnidca's Avatar
Default Re: abs problem (accordredliner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">
Also, how do u get the error code?</TD></TR></TABLE>
Jump the service check connector.
Old Oct 1, 2005 | 11:04 AM
* B A N N E D *
thanks. I got code 1 which is abs motor over run.
How do I fix that?
Old Oct 1, 2005 | 11:08 AM
Chiovnidca's Avatar
Default Re: (accordredliner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">thanks. I got code 1 which is abs motor over run.
How do I fix that?</TD></TR></TABLE>
Usually need to bleed the air out of the system. Might want to fix your leak too.
Old Oct 1, 2005 | 11:21 AM
* B A N N E D *
I bled and filled it already. No dice.
Where do leaks usually occur?
Does buzzing indicate low fluid level?
Old Oct 1, 2005 | 03:46 PM
Chiovnidca's Avatar
What year and model?
Does buzzing indicate low fluid level?</TD></TR></TABLE>
That noise is from the motor running. Usually if it runs too long it's from air in the abs system.
Old Oct 1, 2005 | 03:57 PM
HondaTechPro's Avatar
The leak usually occurs inside the accumulator. This is a very common failure on the older accords, and due to the cost of parts, usually we recommend not fixing it. The regular brakes will work fine.
Old Oct 1, 2005 | 04:05 PM
P_Adams's Avatar
Accumulator "o"ring for one.
#3 in the supplied illustration
http://www.hondaautomotivepart...LATOR
P
Old Oct 1, 2005 | 06:39 PM
* B A N N E D *
i have 95 accord EX V6. Is this a typo?
115649 008 1 MODULATOR ASSY. NO COLOR 1533.69 1150.27 Qty:
115650 009 3 BOLT, ABS MODULATOR
how can it cost over 11k?
Old Oct 1, 2005 | 06:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">i have 95 accord EX V6. </TD></TR></TABLE>
The abs modulator plugs usually leak on those. There's a service bulletin on how to reseal them.
Old Oct 1, 2005 | 07:28 PM
P_Adams's Avatar
You're looking at the complete assembly, and yes; that's the freight on that puppy OUCH!!!
The good news is that it is servicable (rebuildable) where certain offending parts can be replaced individually.
P
Old Oct 2, 2005 | 12:38 AM
* B A N N E D *
Default Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">You're looking at the complete assembly, and yes; that's the freight on that puppy OUCH!!!
P</TD></TR></TABLE>
I bought that car for 11k so ur saying the module also cost 11k???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">The abs modulator plugs usually leak on those. There's a service bulletin on how to reseal them.</TD></TR></TABLE>
Where is the modulator plugs located? Do you have a copy or know where I can get the service bulletin on how to reseal the plugs?
Old Oct 2, 2005 | 05:05 AM
Chiovnidca's Avatar
Where is the modulator plugs located? Do you have a copy or know where I can get the service bulletin on how to reseal the plugs? </TD></TR></TABLE>
Sent a copy to the email in your profile.
Old Oct 2, 2005 | 08:01 AM
* B A N N E D *
thank you. off topic but I can't find a link to my HT's email.
Old Oct 2, 2005 | 09:05 AM
Chiovnidca's Avatar
https://honda-tech.com/zero...37401
Old Oct 2, 2005 | 05:26 PM
* B A N N E D *
but where is the email that you have sent me??? I can't find any type of mail box link
Old Oct 3, 2005 | 08:13 AM
* B A N N E D *
thanks I got the file.
Is it neccessary to flush the conventional brake after the abs module is install after removal?
Old Oct 3, 2005 | 11:49 AM
Chiovnidca's Avatar
Is it neccessary to flush the conventional brake after the abs module is install after removal?</TD></TR></TABLE>
You'll need to bleed the air out of the system.
lovelove
Suspension & Brakes
Feb 11, 2013 03:04 PM
HiChanDC2R
Jul 18, 2006 10:16 AM
Darkray16
Feb 2, 2006 10:11 PM
rhd
Nov 10, 2005 06:25 PM
