ABS Light!! Need Help!
Old Oct 20, 2007 | 07:52 PM
BOOSTED_JDM_DB8's Avatar
Default ABS Light!! Need Help!
when i was driving, my negative battery cable came lose. this happen to me before, my abs would come on then later i started the car again it would turn off. But this time it turn off for awhile then later it turn on again. i already took the battery cables off and put back on, it still wont turn off. I check fuses already and the fluid.
Any other ideas it might be?
Old Oct 20, 2007 | 08:04 PM
ac_attak's Avatar
Default Re: ABS Light!! Need Help! (BOOSTED_JDM_DB8)
Check the "integra forum faq" sticky at the top of the forum, the first link in there will explain to you how to pull the code.
Old Oct 20, 2007 | 09:26 PM
Mfoehrkolb's Avatar
take the light bulb out of the cluster
Old Oct 20, 2007 | 11:26 PM
vietnamezerice's Avatar
Default Re: (Mfoehrkolb)
check some grounding points, and check your abs sensors
bonstokLS
Mar 30, 2014 10:51 PM
njmad
Dec 15, 2009 02:10 PM
hulk_22
Sep 6, 2006 09:57 PM
cdoucet
Jan 28, 2006 04:08 PM
redteg1
Aug 18, 2001 02:42 PM
