97 gsr idle problem
Old Oct 18, 2007 | 07:06 PM
mike1jag's Avatar
Default 97 gsr idle problem
i ahve a 97 gsr motor has after market intake ,70mm thrtle body, aem fuel rail,310 rs injectors and a few other things. I cant seem to get it to idle right it drops down to like 500 rpms or lower than shoots up like 1500 to 2000rpm it will run like that for a while then drop down again. any ideas or sugestions would be great
Old Oct 18, 2007 | 08:19 PM
all-mtr-teg's Avatar
Default Re: 97 gsr idle problem (mike1jag)
what else is done that requires a 70mm TB and 310 injectors, did you get a tune? Got any aftermarket cams, header, headwork, etc?
Old Oct 19, 2007 | 10:17 PM
mike1jag's Avatar
Default Re: 97 gsr idle problem (all-mtr-teg)
it had a turbo on it but the kid burned up a piston. then took it to a local shop and had a new engine built. I was told it had stage 3 cams it has a full apexi exhst (header back) with a cat. I was also told it has new pistons and rods set up for nos. I am going to take off the valve cover tomorrow and see what kind of cams are in it. plus I pulled out the RC 310 inject and put some stock ones in. it runs alot better but still does the idle thing. Plus I changed the Iacv and that didnt help.
Old Oct 20, 2007 | 06:30 AM
almostdone3's Avatar
...is the car tuned?
and lol at "engine ready for NOSSSS"
Old Oct 20, 2007 | 10:44 PM
mike1jag's Avatar
Default Re: 97 gsr idle problem (almostdone3)
no I dont think it has been tuned it is the stock ecu p72. Iam trying to hold off on changing the ecu over to obd1 and then get like a hondata unit.
Old Oct 20, 2007 | 11:29 PM
vietnamezerice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1jag &raquo;</TD></TR><TR><TD CLASS="quote">no I dont think it has been tuned it is the stock ecu p72. Iam trying to hold off on changing the ecu over to obd1 and then get like a hondata unit. </TD></TR></TABLE>
sounds like a plan
jameson_g
Dec 13, 2012 08:11 PM
defaced8
Apr 9, 2007 04:57 PM
8YourV8
Nov 17, 2006 11:57 AM
escourt23
11
Dec 2, 2005 08:14 AM
