abs light on and breaking issue
Old Jun 9, 2009 | 10:37 AM
krazyk606's Avatar
Default abs light on and breaking issue
issue solved. please delete
Old Jun 9, 2009 | 04:33 PM
vtecb20gsr's Avatar
New User
Default Re: abs light on and breaking issue
Check the code... abs doesn't work when the light turns on. Might be a speed sensor? The pushing up on your pedal feeling sounds like abs?
Old Jun 9, 2009 | 10:52 PM
krazyk606's Avatar
okay but it only happens when the light is off?
Old Jun 10, 2009 | 01:48 PM
krazyk606's Avatar
anything?
Old Jun 15, 2009 | 07:17 AM
krazyk606's Avatar
Old Jun 15, 2009 | 07:32 AM
Dogginator's Avatar
Daisy... Daisy...
A bad sensor can cause a false reading and reduced braking before the light is set. Pull the ABS codes to read them.
This situation is dangerous beofre the light sets due to the braking issues. Once the light is set, you have conventional brakes, as the ABS is disabled. If you cannot fix it soon, consider pulling th ABS fuse to have conventional brakes that will predictably work.
laurn
Suspension & Brakes
Feb 18, 2013 07:30 AM
prelude_93vtec
Apr 11, 2007 05:09 PM
dblas
Acura TL, RL & ZDX
Feb 23, 2007 02:40 PM
