ABS help!!
Old 10-14-2008, 10:12 PM
DoHcV-tEc's Avatar
Default ABS help!!
well just put in a new (well not new but used) abs accumulator in my 1995 integra gsr did everything good well not really the only this is bleeding sequence which its killing me now i went to acura dealer told them my story and they told me now i have to bleed all the line that lead to the abs accumulator and mc could someone plz help me with this abs cause it killing me thanks for your advice and help
Old 10-15-2008, 09:39 AM
sh4mr0ck's Avatar
Default Re: ABS help!! (DoHcV-tEc)
If you fill your brakes from the ABS unit, you should be able to just bleed to lines on your wheels.
Old 10-15-2008, 12:01 PM
DoHcV-tEc's Avatar
did that still nothing.......... they told me that i would have to bleed the ABS lines then the brake lines.. they also told me that its nearly impossible to take all the air out of the ABS lines... any other suggestions thanks again
Old 10-15-2008, 12:04 PM
akandok's Avatar
SEARCH?
1st google result for "integra bleeding abs"
http://www.g2ic.com/forums/showthread.php?t=170107
Old 10-15-2008, 12:46 PM
vietnamezerice's Avatar
Default Re: (akandok)
vacuum bleed it
Old 10-15-2008, 12:47 PM
DoHcV-tEc's Avatar
with all do respect.. i did my HW before i posted this.. i tried doing that and all these other ways i found from previous search matches i found... for some reason the light stays off... but when and if you turn the car off then back on twice, the light turns back on..... im just tired of messing with it
Old 10-15-2008, 12:49 PM
DoHcV-tEc's Avatar
Default Re: (vietnamezerice)
vacuum bleed it
yea thats what i found today while i did some more research.... but i dont know how to do it any tips THANKS
Old 10-15-2008, 10:18 PM
Default Re: (DoHcV-tEc)
there's a special tool that hooks up to a compressor... then you squeeze the lever and it provides suction... that's what a vacuum bleeder is
Old 10-15-2008, 10:48 PM
racebum's Avatar
agree with the others. harbor freight or sears have vacuum bleeders that are pretty simple to use. the instructions walk you through how to use one. remember it's a line filled with fluid. visualize it sucking just like your girlfriend. you know what happens next.
Old 10-15-2008, 11:10 PM
Default Re: (idrivesideways)
i know what happens next alright
Old 10-16-2008, 07:19 AM
DoHcV-tEc's Avatar
alrite thanx for the HEADS UP im gona get that vaccum today i looked up on line so probably work on it this weekend thanks again
Old 10-16-2008, 07:38 AM
HondaHeddie's Avatar
The manual (worth every penny) shows a special tool
# 07HAA-SG00101
"Bleeder T-Wrench"
it has a long neck with a resevoir on top to allow bubbles to rise out of the abs system
do the right thing, by the factory manual(s)
Old 10-16-2008, 07:47 AM
DoHcV-tEc's Avatar
Default Re: (HondaHeddie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHeddie &raquo;</TD></TR><TR><TD CLASS="quote">The manual (worth every penny) shows a special tool
# 07HAA-SG00101
"Bleeder T-Wrench"
do the right thing, by the factory manual(s)</TD></TR></TABLE>
wouldnt that be kind of like the vacuum device?? ill look in to that to THANX
Old 10-17-2008, 10:21 PM
DoHcV-tEc's Avatar
ANYONE ELSE!!!!
Old 10-17-2008, 11:02 PM
racebum's Avatar
what do you need more opinions for? you haven't even tried the vac bleeder have you? do that and report back.
maxboost_50psi
09-08-2006 07:20 AM
cambopheonix56
07-17-2005 09:04 PM
95greenteg
09-16-2004 09:10 PM
Quick Reply: ABS help!!
