95/2000 ls differences?
Old May 22, 2004 | 08:33 AM
Sarren's Avatar
Default 95/2000 ls differences?
I'm considering buying a 2000 LS, what exactly are the differences between some of the older and newer ls's? I know the whole obd 1/2 thing, but other then that? Performance wise, is there much of a difference?
Old May 22, 2004 | 10:35 AM
boost fed ls's Avatar
Default Re: 95/2000 ls differences? (Sarren)
the diff between a 95 and a 2000 is mostley exterior and interior than performance. The diff in exterior is the bumpers, headlights are a little smaller on the 95, taillights, wheels(2000 have 15nch mesh wheels and the 95 have 14nch hub caps) 95 has the trunk release inside the car and the 2000 have the trunk release lever in the rear of the car. Just little stuff like that. The motor is the exact same(except valve cover is diff).
Old May 22, 2004 | 11:41 AM
zilverz's Avatar
Default Re: 95/2000 ls differences? (boost fed ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls &raquo;</TD></TR><TR><TD CLASS="quote">the diff between a 95 and a 2000 is mostley exterior and interior than performance. The diff in exterior is the bumpers, headlights are a little smaller on the 95, taillights, wheels(2000 have 15nch mesh wheels and the 95 have 14nch hub caps) 95 has the trunk release inside the car and the 2000 have the trunk release lever in the rear of the car. Just little stuff like that. The motor is the exact same(except valve cover is diff).</TD></TR></TABLE>
Well the sensors on the motor is different.
2000 is OBD-II
1995 is OBD-I
Old May 22, 2004 | 04:41 PM
ernald711's Avatar
i read that if you beefed up both motors the same way the 95'll take out the 2000. forgot where i read that....
Old May 23, 2004 | 11:09 AM
Default Re: 95/2000 ls differences? (zilverz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zilverz &raquo;</TD></TR><TR><TD CLASS="quote">
2000 is OBD-II
1995 is OBD-I
as stated in the org. post
Old May 25, 2004 | 08:13 PM
zilverz's Avatar
as stated in the org. post</TD></TR></TABLE>
To be honest, I did miss that in the original posting, OBDI/II.
But that is about the only performance difference I know of. the On Board Diagnostics and how the ECU reacts to its readings.
Old May 26, 2004 | 07:51 AM
aeon's Avatar
Default Re: 95/2000 ls differences? (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">i read that if you beefed up both motors the same way the 95'll take out the 2000. forgot where i read that....</TD></TR></TABLE>
I don't think there's that much of a difference, but the obdII does hold it back a little bit. ODB II is more sensitive and OBD I responds easier to the mods
Old May 26, 2004 | 07:59 AM
SuzukaBlueAP2's Avatar
Yet another person that seems to believe all that they read...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">
And you still believe that there is an advantage with OBDI over OBDII?
Anyways...back to the original thread starter...
There is a 2 hp difference in the 95 and 2000ls engine ratings. The 95 is rated at 140, and the 2000 is rated at 142. It's not going to make or break you.
The front and rear fascia's are different, the mirrors are different, and the 2000 probably comes with GS-R wheels. Not to mention the 2000 has the immobilizer built into the ECU. Off the top of my head, that's all I can think of.
Old May 26, 2004 | 08:28 AM
95teggyls's Avatar
Default Re: 95/2000 ls differences? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">
There is a 2 hp difference in the 95 and 2000ls engine ratings. The 95 is rated at 140, and the 2000 is rated at 142. It's not going to make or break you.</TD></TR></TABLE>
No i read the specs of a 95 teg ls "like mine" and it stated that the b18b had 142hp.
no matter what year.
Old May 26, 2004 | 08:47 AM
Default Re: 95/2000 ls differences? (95teggyls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95teggyls &raquo;</TD></TR><TR><TD CLASS="quote">
no matter what year.</TD></TR></TABLE>
Could be...maybe I was thinking of the B18A1...but I thought that was 130...either way...It doesn't make a big difference.
Old May 26, 2004 | 09:19 AM
zilverz's Avatar
Could be...maybe I was thinking of the B18A1...but I thought that was 130...either way...It doesn't make a big difference.</TD></TR></TABLE>
No the B18A is 140hp
the ZC is 130hp
710times
Jul 4, 2018 07:53 PM
Jdm_Honda_Integra
Jan 20, 2005 04:32 PM
SM Polishing
Jan 8, 2003 05:26 AM
