93 Integra GS questions
Not new to Honda-Tech but new to integras. Just picked up a 93 integra gs 5spd. Car has a swap b18 and tranny but has some issues. Mechanically the car is sound except for a oil leak. My biggest problem is the shift linkage it was loose as hell. Bought new poly bushings didnt help then I noticed the u joint thats closest to tranny had play I did the eclip fix its helped alot of play but then whislt I was there removing the linkage I noticed the hole for the linkage was smaller then the tranny. I drilled the linkage hole wider and put a pin more snugg to hold the two better. I still have play within the shifter. The tranny has no model number just a casting stamp YSK 1
Re: 93 Integra GS questions
Take a look at the other end of the linkage, the part that's under the shift lever. The bushings there wear out and cause a large amount of side-to-side slop in the lever.
Bump to this post.
Finally got the car running and driving good amd decided just to get a new linkage my friend has a DC linkage in his garage. It bolts right in correct? Ive done research and its all around better but I still dont know why the hole on the tranny is that big for the linkage pin tonlock in to it. I drilled the linkage and put a bigger pin worked for a little now its loose again.
arrojj
07-11-2011 12:21 PM
preludedriva
16
08-08-2007 03:48 PM
