92 integra starting problem ecu code 8
hey guys,
i have a 92 integra ls, with about 180k, stock for the most part..
sometimes it wont start.. when i click the key to start it.. nothing
no cranking no turning over nothing.. its as if the battery is completely dead.
i can hear the fuel pump prime so its probably not that.. usually when i come back to the car after a couple hours it will start up fine no problems..
i had to clutch start it today.. it clutch starts fine..
sometimes i can get it started if i hold the key in the starting position. sometimes when i hold it in the starting position it'll throw a code..
it throws a code 8 and i searched everywhere and people say its the tdc sensor in the dizzy.. so maybe a new dizzy..
this happen to anyone else.. any ideas or suggestions??
i hate getting stranded...
TIA
TIA
if you have power and your starter does not click, you might have a dead spot in it. take it to autozone and they will run a free test on it
you may want to check to make sure the one wire spade connector is on the starter real good too
just because its throwing a code the car should still in theory crank over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution »</TD></TR><TR><TD CLASS="quote">
just because its throwing a code the car should still in theory crank over</TD></TR></TABLE>
i was thinking that as welln
well the car did it a few more times on my way home yesterday.. good thing its in the garage so i can troubleshoot at home instead of in the parking lot of work or at the mall where it happened both times yesterday haha..
its a PITA pushing the car by yourself trying to clutch start it..
just not to confuse you guys.. i am the one that started this thread.. ianfromdaygo is an old log in name i used cause i couldnt remember the password to this one haha
UPDATE -
got a new dizzy
battery was dead.. jumped the car and it worked and ran fine...
drove to a buddies house.. parked... when it came time to leave the car was dead again...and had to jump it to go home
so today i bought a new battery and it still wont start unless its being jumped...
it is STILL throwing a code 8
i have no idea what the heck is going on...
any suggestions or ideas are welcomed..
TIA
got a new dizzy
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crash my EG »</TD></TR><TR><TD CLASS="quote">did you check the ground on the starter?</TD></TR></TABLE>
ive checked the ground on the starter... but now im thinking since i have a relocated battery.. to check the ground in the trunk....
esp since it needs another car hooked up to it to crank...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">you need a new starter dude. your starter solenoid is done , id bet on it.</TD></TR></TABLE>
i can take it out and try to bring it autozone or somewhere to test it right?? hmm maybe ill try that tomorrow.. thanks!
FTMFW
i beat the **** out of the starter this morning and it started fine... thaanks
FTMFW
just my luck...
i buy a starter at the junkyard... bust my *** all day long to try to get it in.. and its just a hairline off and wont bolt up..
so i call the junkyard to ask them what time they close... and their answer...
"right now"..
argh
"right now"..
argh
I had a problem like this happen to me before. For the longest time i couldnt figure it out. In the end it ended up being the main relay... Once I switched it out i didnt have a problem anymore with it not starting. just a thought...
Burke
May 8, 2004 06:12 AM
