92 integra lsvtec overheating problem!!
Old Sep 22, 2007 | 07:07 PM
bsballboyjk's Avatar
Default 92 integra lsvtec overheating problem!!
im gonna go nuts can someone pleease help me. my car keeps over heating, but for the most part only when i am stopped/idling or in slow traffic.
p.s. trust me i've been searching all day.
brand new ls vtec motor in a 92 gsr. there are no leaks, i am not losing any coolent at all. radiator is fairly new and has been flushed recently. when filled it i bled the system correctly so i dont think there is a problem with flow at least from an air lock or something. i also bought a new oem thermostat when i did the swap so there shouldnt be a problem there...
so far i've replaced the thermostat switch? (sensor that goes into thermo housing) and the water temp sensor (one that goes into the head).
i know that both of my fans (radiator/ac) are hooked up and seem to be working because when i turn on the ac both fans come on. i also jumped the plug at the themostat sensor plug, turned the car to accesories and both fans came on w/o having to have the ac on.
the weird part of all of this is that when i turn off the car the the fan comes on to cool things and usually just stays on for about 10 minutes after shut off. if i turn the keys to accesories, it shuts the fans off, and as soon as i take it back off accesories, the fan turns on again.
what is going on here??? any suggestions are greattttly appreciated
Modified by bsballboyjk at 6:34 PM 9/23/2007
Old Sep 22, 2007 | 07:17 PM
tamparacer's Avatar
Default Re: 92 integra lsvtec overheating problem!! (bsballboyjk)
Do your fans come on and turn off while at operating temp without jumping or using the ac? I believe there is a relay or wiring issue.
Old Sep 22, 2007 | 07:31 PM
Default Re: 92 integra lsvtec overheating problem!! (tamparacer)
no should the fan come on when the car reaches operating temp? i didn't know but yea i've let it sit and idle for ever even after beating on it and i've never seen the fan comes on, and then it starts to slowly overheat. any more info on that relay? where is it at and how do i test it?
Old Sep 22, 2007 | 07:45 PM
tamparacer's Avatar
If I'm not mistaken, and I don't think that I am, the coolant temp sensor tells the relay to turn on and off the fan(s) to keep you within a specific operating temp range.
I'd check the relay first.
Modified by tamparacer at 8:09 PM 9/24/2007
Old Sep 22, 2007 | 07:47 PM
tamparacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsballboyjk &raquo;</TD></TR><TR><TD CLASS="quote">any more info on that relay? where is it at and how do i test it?</TD></TR></TABLE>
Never owned a 92, nor do I know the location or exact configuration of the relay or wiring. Do a search for fan relay for your car.
Old Sep 22, 2007 | 07:55 PM
tamparacer's Avatar
Old Sep 23, 2007 | 07:23 AM
wow thank you soooo much that is awesome. thanks for all your help. i'l let you know what it ends up being when i figure it out.
Old Sep 23, 2007 | 09:13 AM
idriveahonda's Avatar
Same thing happened to me. Didn't know it, but I had a blown headgasket. Same thing, just fine when driving, but when stopped, overheating came in.
Good luck.
Old Sep 23, 2007 | 09:35 AM
Type Wah's Avatar
SUBSRIBING
seems like i'm having the same problem
would like to solve it before it becomes a bigger probl
em
Old Sep 23, 2007 | 05:37 PM
Default Re: (Type Wah)
didnt figure it out yet, but just wanted to say i don't really think it is the headgasket or at least really hope not. i wouldn't see how it could be bad when it was a brand new oem headgasket and has less than 60 mi on it. also my oil looks like oil and i dont see any coolent on the stick when i pull it.
Old Sep 23, 2007 | 09:04 PM
DAtegLs's Avatar
d*mn...im havin the same problem with my 91 ls...i just put my 92 rs motor in it and it started then...
Old Sep 24, 2007 | 06:55 PM
tamparacer's Avatar
Default Re: (bsballboyjk)
I would be surprised if I'm not correct.
If your fan isn't going when the engine heats up you are going to overheat on a warm day.
Old Sep 24, 2007 | 06:59 PM
Default Re: (tamparacer)
ya i know. luckily its cool here in seattle for now. but if it was in warmer weather i would definately be having some serious overheating problems. idk what to do still to get these dang fans to turn on when ther motor is running. it sucks because im getting tuned on friday. i think im just gonna set something up with the fan switch and jump it so the fans will just constantly run while i'm on the dyno.
Old Sep 24, 2007 | 07:07 PM
tamparacer's Avatar
https://honda-tech.com/zerothread?id=558328
This has one good answer to your problem. The person that uploaded the diagram and responded is correct. I forgot his username though. Check it out and get it fixed before it causes other problems.
Old Sep 24, 2007 | 07:09 PM
dayz23's Avatar
man my **** is doin the same. I dont know what happen. Today it actually started smokin up on me, i couldnt get off the road and park in time. Some one else also told me it might be my headgasket...
Old Sep 24, 2007 | 07:10 PM
tamparacer's Avatar
Default Re: (dayz23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dayz23 &raquo;</TD></TR><TR><TD CLASS="quote">man my **** is doin the same. I dont know what happen. Today it actually started smokin up on me, i couldnt get off the road and park in time. Some one else also told me it might be my headgasket...</TD></TR></TABLE>
If your fan wasn't working, it would cause you to overheat and a blown headgasket would be the result, not the cause. The smoke was probably steam from your coolant in the combustion chamber, from the blown headgasket.
Old Sep 25, 2007 | 07:58 AM
dayz23's Avatar
So it is a blown head gasket? After i took it off the road i actually realized taht the pvc tubing going from my radiator to my engine was leaking right at the seal of the two. I dont know if that had anything to do wit it, but i fixed that up. Now im too scared to drive my car with out knowing the full problem. I dont wanna loose my engine.
And i know its not my fan because i already checked that first and it was working proper.
Old Sep 25, 2007 | 10:41 PM
problem solved...
never guessed it would have been that my brand new oem thermostat would be bad and not be opening all the way...
lol at least they gave me my $ back.
i realized this finally was the problem because the fluid was not circulating too well and also the lower radiator hose was much cooler than it should be at operating temp.
anyways thanks for all the help
Old Sep 26, 2007 | 04:22 AM
tamparacer's Avatar
I'd still check out the fans if they don't come on by themselves., but glad to see you got that fixed.
Old Sep 26, 2007 | 05:37 AM
J's 94 Accord's Avatar
why dont you just wire the fans up to a switch inside the cabin and operate it manually?
Old Sep 26, 2007 | 05:44 AM
VTEC_PRODUCTION's Avatar
Default Re: (J's 94 Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J’s 94 Accord &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just wire the fans up to a switch inside the cabin and operate it manually?</TD></TR></TABLE>
that is ghetto...the way to fix things is to do it right...
Old Sep 26, 2007 | 06:16 AM
Default Re: (VTEC_PRODUCTION)
ya i did check. now both fans turn on and off when the car is running and gets up to operating temp. thanks
Old Sep 26, 2007 | 06:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
that is ghetto...the way to fix things is to do it right...</TD></TR></TABLE>
I dont see how. Explain. Just because I'd like to have control of my fans?
Old Sep 26, 2007 | 12:48 PM
tamparacer's Avatar
Now that the thermostat opens, the coolant temp will kick on the fans!
Old Sep 26, 2007 | 03:41 PM
dc2415's Avatar
Default Re: (idriveahonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveahonda &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me. Didn't know it, but I had a blown headgasket. Same thing, just fine when driving, but when stopped, overheating came in.
Good luck.</TD></TR></TABLE>
same story here with me
React94
Apr 30, 2013 01:31 PM
turboeg954
14
Nov 2, 2011 08:15 AM
downstarinc
Jul 5, 2007 01:49 PM
MR-MUGEN
Nov 9, 2004 09:31 AM
