cooling problem
Old Nov 7, 2004 | 02:45 AM
MR-MUGEN's Avatar
Default cooling problem
okay heres my problem i have 92 DA integra with ls/vtec-- just to point out not just a cheap ls/vtec its done rite-- any who.. my problem is this my car is always at like 150-160 F but when i drive slow it will sometimes go to like 190 F witch is okay i think ... but if i step on it the temp. will go down to about 110-130F , that the car check and , mechanic said everything is okay . no problems that maybe , i need a new radiator , please any comments and help would work
Old Nov 7, 2004 | 06:06 AM
ogabudiah's Avatar
Default Re: cooling problem (jdm92daintegra)
If you need a new radiator then change it and see how it does. If thats not it try the thermostat.
Old Nov 7, 2004 | 06:47 AM
stasi's Avatar
Default Re: cooling problem (ogabudiah)
Bleed the system, you may have air in there. If that doesn't work, get a new radiator.
Also, it's spelled "right", not "rite". There's many occasions I don't respond to people's posts because they either have horrible grammar or can't spell.
Old Nov 7, 2004 | 09:42 PM
MR-MUGEN's Avatar
Default Re: cooling problem (stasi)
sorry for spelling it wrong man ... all roll over and die now ...
but everything is new ( coolant system ) except the radiator
Old Nov 7, 2004 | 09:52 PM
PhantomSTi's Avatar
Get an Aluminum Radiator, Like PWR or C&R, Fluidyne.. The reason why your temp is going down when you step on it is the ram air.. (Well, that was a dumbass statement, but I'm just clarifying).
Old Nov 8, 2004 | 09:38 AM
MR-MUGEN's Avatar
Default Re: cooling problem (90integra05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90integra05 &raquo;</TD></TR><TR><TD CLASS="quote">Get an Aluminum Radiator, Like PWR or C&R, Fluidyne.. The reason why your temp is going down when you step on it is the ram air.. (Well, that was a dumbass statement, but I'm just clarifying).</TD></TR></TABLE>
ram air what the f&% ..... you talking about
Old Nov 8, 2004 | 09:47 AM
burnout289's Avatar
I think he means that when you speed up, more air is pushed thru the radiator and cools down the fluid.
when you say you "step on it" how fast are you going? are you just talking about a quick romp or do you mean when you are going like 40+mph? the reason I ask is that when going slow, the fans keep air moving through the radiator, but when you get going faster, more air is moving due to your speed than the fans would pull. I would make sure your fans are coming on when they are supposed to.
as for you mechanic saying "maybe you need a new radiator", I say take it to a radiator shop. I spent a bunch of money hunting down an overheating problem on my Mustang and finally broke down and took it to the right place. they popped the tanks off and saw the problem and fixed it. in the end I spent less time/money having them rebuild it than I did replacing the wrong parts. a regular mechanic won't always look at the cooling system the way a radiator/cooling specialist will.
Old Nov 9, 2004 | 01:02 AM
MR-MUGEN's Avatar
Default Re: cooling problem (burnout289)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout289 &raquo;</TD></TR><TR><TD CLASS="quote">I think he means that when you speed up, more air is pushed thru the radiator and cools down the fluid.
as for you mechanic saying "maybe you need a new radiator", I say take it to a radiator shop. I spent a bunch of money hunting down an overheating problem on my Mustang and finally broke down and took it to the right place. they popped the tanks off and saw the problem and fixed it. in the end I spent less time/money having them rebuild it than I did replacing the wrong parts. a regular mechanic won't always look at the cooling system the way a radiator/cooling specialist will.</TD></TR></TABLE>
thanks man , and what i mean by " step on it " is when i get up on my rpms not mph
Old Nov 9, 2004 | 04:39 AM
92SLEEPER's Avatar
swap out thermostat if u havent already, and if it still does it ,check for air pockets, and if all fails,f@%k it, swap out radiator
Old Nov 9, 2004 | 09:31 AM
MR-MUGEN's Avatar
Default Re: (Aldana_R@hotmail.com)
ya its a greddy thermostat.... but i might start parting ,my car , have some money problems at the time
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
thakidd
May 15, 2008 01:45 PM
cilvia
15
Feb 16, 2007 09:47 AM
viperguy
Jun 20, 2003 09:35 AM
intekragsr
Feb 5, 2003 02:19 PM
