92 integra converted to type r 5 lug conversion.
Old 12-16-2005, 10:13 AM
CivicEG29's Avatar
Default 92 integra converted to type r 5 lug conversion.
Hey i got a 92 integra which you all know is a 4 lug/ I had like a thought but wasnt to sure if it would be possible to convert my 4 lug suspension to a type r 5 lug suspension. And if it is worth it in the end and if its possible get at me.
Old 12-16-2005, 10:16 AM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Default Re: 92 integra converted to type r 5 lug conversion. (integrada)
Well, the only benefit of this is the bling status. There is no function gain from the modification, and yes it is possible. My brother and I have tossed the idea around of doing one on his DA9.
tequilakid's Avatar
Sure it can be done, and it has been done. Keep in minf that it is more work then a g3 integra and eg/ek civics becuase something needs to be machined, search and im sure you'll find it in no time.
rookn00b
xtrac1's Avatar
I'm in the process of converting to 5 lug. Heres some websites with some info
http://www.ff-squad.com/technet/how-to/5lug.ef-da/
http://battlecat.8m.com/ITR%20...A.htm
Good luck
Old 12-16-2005, 10:20 AM
JDM-EJ1's Avatar
Default Re: 92 integra converted to type r 5 lug conversion. (xtrac1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtrac1 &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck </TD></TR></TABLE>
Good info.
Old 12-16-2005, 10:33 AM
CivicEG29's Avatar
Hey you all the info you';s gave me help me out alot. It seems that its not as difficult as i thought it would be but it isnt no easy task . well thnx for all the info and thanxs for being there.
Old 12-16-2005, 10:37 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrada &raquo;</TD></TR><TR><TD CLASS="quote">Hey you all the info you';s gave me help me out alot. It seems that its not as difficult as i thought it would be but it isnt no easy task . well thnx for all the info and thanxs for being there. </TD></TR></TABLE>
It's only as easy as you make it. Make sure you have all the parts on hand when you start this, have a good idea of what you need to do when going into it. Make sure you have all the correct tools to get the job done. Also, give yourself an ample amount of time to do it, so if you do make a mistake, or something goes wrong you won't be out a car.
m1k3y18
05-13-2010 12:36 PM
milligan41088
07-05-2006 07:13 PM
2000_EJ
04-29-2004 07:11 AM
1JDMDOMINICAN
11-25-2003 08:41 AM
zentraedityper
10-23-2001 07:51 PM
Quick Reply: 92 integra converted to type r 5 lug conversion.
