5 Lug on a DA
Hey all..i have been registered here for a while just never had anything to post about..i have a question for you all
There was a Black Integra (90-93) on here that had a ITR suspension swap done to it. I used the search tool and could not come up with what i was looking for. If anyone out there could point me in the right direction it would be really appreciated. I love this website..and hopefully will start to have more to post about. Thanks in advance.
Yup.. its the five lug converstion.. if you type in "lug conversion" or 5 lug conversion" you shoudl be able to find a few threads on it.. not many DAs have it though.. I found a few hatches n crx. anyways good luck finding what you need.
Welp, that doesn't help much I guess...but...anyho, I have read that the front hubs need to be machined about .5mm on the DC 5 lug in order to run the stock DA size wheel bearing and to retain the proper suspension geometry of the original setup on the DA. Anybody who has actually done this setup have anything to say? I am going to be the one running this setup that 2000EJ posted about, reason being that this is going to be a tracked car and running 4 piston front calipers and upgraded everything else. Please post if you have any tips or whatever. Thanks in advance.
Pat.
Pat.
Guest
Posts: n/a
There are four pistons units for our car, I have been running them for years... There is no reason to totally change to Five lugs unless your looking for, well I don't know what. I nothing but props for my friends that have pioneered this swap, but it woun't make you faster at the track. Another thing is you do not have to do a total 5 lug modification to run good suspension, hence my hybrid comment... but I guess you knew that
