92 integra cel code 43. help me
Old Dec 5, 2012 | 06:34 AM
bendersquad's Avatar
Icon2 92 integra cel code 43. help me
Check engine light is on for my integra. Code 43 (fuel supply system. Starts fine no problem runs great for a while then a sudden loss of power. Drops then I have to tap on gas pedal to get it going. Almost like it wants to shut off. I was told that the main fuel relays go out on these integra's but I can hear and feel the two clicks while key is in the "on" position and the third click when I start the car. I don't really hear the fuel pump but honestly, I don't know what I should be listening for. Lol. So any help on this subject would brighten my day.
Old Dec 5, 2012 | 08:13 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 92 integra cel code 43. help me
Check here about 2/3 down the page
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Dec 6, 2012 | 07:34 AM
Yeah that explained some things but not the solution to my problem. Think I'm just gonna get a new field pump and see how that goes. Thanks for your help.
Old Dec 6, 2012 | 07:35 AM
Fuel**
Old Dec 6, 2012 | 07:52 AM
fcm's Avatar
fcm
Old Fart
Tossing parts at a problem is an expensive way to troubleshoot a problem, you should be testing the fuel pump and checking the fuel pressure before just replacing th pump, a lot of work on a G2. 94
Old Dec 8, 2012 | 11:26 AM
rd91sib18c5r's Avatar
Code 43 is usually caused by a bad o2 sensor or bad fpr.
Old Dec 12, 2012 | 06:10 PM
TKATS_EF's Avatar
i had that happen onmy 91 DA and it resulted to be an injector. Same symptoms. i would give it gas and it would want to fall on its face...if i feathered it it would somewhat help it smooth out. place a long screwdriver on the metal part of the injector body when the car is idling, then place your ear on the screwdriver handle...you should hear some clicking coming from the inside of the injector. If you do it means the injector drivers are working...its a rough diagnostic but it might help you
Old May 2, 2013 | 11:08 AM
Delsolb16r's Avatar
I had code 43 too. I added a permanent fuel pressure gauge to my 92 Integra, it helps a lot with diagnosing. I had no fuel pressure. I soldered the main relay, and I had 12 volts going to the fuel pump so I changed the fuel pump. then I only had 32 pounds at idle in the car. still seemed very weak later I was driving and code 43 came back again, I change the fuel pressure regulator ,cranked the car up and now I have 38 pounds of fuel pressure. I think the bad regulator was over working the pump that's why It burned out. hope this helps people in the future
Old May 10, 2013 | 02:03 PM
Delsolb16r's Avatar
I had code 43 too. I added a permanent fuel pressure gauge to my 92 Integra, it helps a lot with diagnosing. I had no fuel pressure. I soldered the main relay, and I had 12 volts going to the fuel pump so I changed the fuel pump. then I only had 32 pounds at idle in the car. still seemed very weak, and later I was driving and code 43 came back again, I change the fuel pressure regulator ,cranked the car up and now I have 38 pounds of fuel pressure. I think the bad regulator was over working the pump that's why It burned out. hope this helps people in the future. .... ******UPDATE**** The cel code 43 for fuel system issue came back. I replaced the o2 sensor with a new one from autozone. Now the code has not returned, and I am getting better gas mileage now.
Old May 11, 2013 | 11:54 AM
sw20 ant's Avatar
old post deleted
thatnikkashoD
Feb 23, 2008 08:54 PM
Rikter
Sep 11, 2006 02:21 PM
TurboEG6
Feb 10, 2005 11:03 AM
Boostless97Lude
Dec 26, 2002 06:55 PM
