91 shell or e85 for track??
Old Nov 6, 2010 | 10:09 PM
l-99-em1's Avatar
Default 91 shell or e85 for track??
Ok so todays i went to Famoso used 91 shell friends suggest i use e85 would it help teach me about e85 fuel.also methanol injection kit.
Old Nov 7, 2010 | 07:37 AM
Spawne32's Avatar
Default Re: 91 shell or e85 for track??
E85 has an octane rating higher than that of regular gasoline's typical rating of 87, or premium gasoline's 91-93. This allows it to be used in higher compression engines which tend to produce more power per unit of displacement than their gasoline counterparts. The Renewable Fuels Foundation states in its Changes in Gasoline IV manual, "There is no requirement to post octane on an E85 dispenser. If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanol’s blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanol’s true octane value should be used to calculate E85’s octane value. This results in an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual octane engine tests." [5]
hckyracer
Jul 22, 2008 10:43 PM
JDM_Spec
Aug 26, 2005 01:34 AM
andysila
Mar 2, 2005 03:25 PM
DJ_CARY
61
Aug 25, 2004 06:28 PM
AllmotorJunkie
Jul 16, 2003 07:03 AM
