91 integra temp problem
Old Jan 14, 2007 | 08:05 AM
advan1320's Avatar
Default 91 integra temp problem
my car takes forever and a day to warm up.when i get on the freeway the temp gauge drops QUICKLY and stays on cold until i come to a complete stop, then goes back up again.its driving me crazy because i dont like driving my car while its cold the whole time! HELP!!
Old Jan 14, 2007 | 08:35 AM
96 EJ8's Avatar
Default Re: 91 integra temp problem (advan1320)
sounds like you need a new thermostat, you can get one from teh dealer for about 30bucks or so dont buy an aftermarket one.
Old Jan 14, 2007 | 08:41 AM
Lewy. Dee Ayy's Avatar
Default Re: 91 integra temp problem (integrada9)
i have the same exact problem..i just bought a new thermostat the other day..i just haven't had time to put it in.
Old Jan 14, 2007 | 08:44 AM
IntegrasAreBest's Avatar
yup definitly sounds like a thermostat problem.
Old Jan 14, 2007 | 08:52 AM
mrmckie's Avatar
same problem here. so its the thermosat huh..
would this also contribute to my radiator fans not coming on??
Old Jan 14, 2007 | 09:01 AM
96 EJ8's Avatar
Default Re: (mrmckie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmckie &raquo;</TD></TR><TR><TD CLASS="quote">same problem here. so its the thermosat huh..
would this also contribute to my radiator fans not coming on??</TD></TR></TABLE>
no for the rad fans you need an Engine Cooling Sensor I bought my sensor for $60 from Acura and the sensor is located behind the block so you need to drain the block from coolant, take out the sensor and put the new one in. then fill it up with coolant and you should be good
Old Jan 14, 2007 | 09:58 AM
Tizight's Avatar
Default Re: (integrada9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrada9 &raquo;</TD></TR><TR><TD CLASS="quote">no for the rad fans you need an Engine Cooling Sensor I bought my sensor for $60 from Acura and the sensor is located behind the block so you need to drain the block from coolant, take out the sensor and put the new one in. then fill it up with coolant and you should be good </TD></TR></TABLE>
He's talking about the Thermo Fan Sensor Part# 37760-p00-004 A dealer on Ebay has new OEM ones for $38.
Old Jan 14, 2007 | 10:03 AM
96 EJ8's Avatar
Default Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">
He's talking about the Thermo Fan Sensor Part# 37760-p00-004 A dealer on Ebay has new OEM ones for $38.</TD></TR></TABLE>
gotcha
Old Jan 14, 2007 | 11:43 AM
Sam92Teg's Avatar
If you are having the same problem as the OP, meaning your coolant temps are never warming up, then the fans will never come on (unless using A/C) because the temp doesn't reach the level that will trip the fan switch. In other words, the switch could be just fine and replacing it won't do anything if the coolant temps are too cold to trip it. Replace the thermostat and then see if the fan comes on when it reaches temp.
EJ1_CRIS_909
Jul 18, 2012 10:03 PM
instructor74
Nov 20, 2008 06:29 PM
b0dteg
Dec 16, 2007 05:27 PM
xXx Justin xXx
21
Mar 19, 2004 05:26 PM
