91 Integra Seatbelt Problems
Hey eveyone.
Ok well Im having a problem with my seatbelts and the light.
I seen alot of people that have the same problem, but couldnt find any specific to mines.
Well first of all, When my seatbelts ARE working correctly, the seatbelt light is still always on. Just wanted to point that out first.
Second, Ive been having a problem with the No. 34 underhood fuse blowing all the time. It seems to only happen when the passenger side seatblet is trying to wrap over someone. Its like the load blows the fuse. Could it be a bad motor?
And third, My driver side seatbelt recently was stuck to the open position. Theres no beeping or anything till i poen the door. The the seatbelt light flashes and beeps continuously. I checked the 23 under dash fuse, 34,35, and 36 underhood fuses, and they are all completely fine.
What else should I be looking at?
All help is appreciated. Thanks.
Re: 91 Integra Seatbelt Problems
Ok today i found out the driver side seatbelt will retract only. I can pull it all the way back over me by hand, but as soon as i open the door it retarctsback off me
Problem solved, pulled the dam plugs from the seatbelt control unit and wound up the seatbelts so I can just use the emergency release everytime I get out lol.
viva60
11-19-2004 02:19 PM
Mr. Vapor
05-12-2003 07:03 PM
