90 LS problems
Old Jun 6, 2007 | 07:39 AM
LSintegra1990's Avatar
Default 90 LS problems
ill try to explain everything as best i can as far as the problems.
it all started when i let my friend drive the car and he was trying to show off and do a burnout and when he rev'd it up and dumped the clutch it just stalled out. after letting it sit for a minute went to restart it and it didn't do anything. let it sit for about 5 minutes and *click click* but didn't start. another 5 minutes and it started right up and drove fine.
yesterday im driving and i take off in 1st gear and as soon as i hit like 3k RPM's it threw a CEL and died. started it back up and it started and as soon as it tried to idle it died out. waited a few minutes it started and stayed running, went to drive and again hit 3k RPM's and it died out. gave it about 5 minutes and it ran fine and i got it home.
later that night i decided to take it for a little drive and see if i could figure anything out. starts right up at my house and drives good. i stop on a street, shut it off and go to restart and same thing, turn the key and nothing. wait a few minutes starts up but dies at idle. wait a few more minutes starts up and runs fine.
any ideas guys??
Old Jun 6, 2007 | 08:12 AM
jaysteven's Avatar
Default Re: 90 LS problems (LSintegra1990)
do you know how to check the codes from the ecu
if so what code do you have
Old Jun 6, 2007 | 08:16 AM
i was actually going to go to the honda dealer today and have them check the codes but when i took the battery out to get it tested i have a feeling that reset whatever codes i may have had since it wasnt hooked up all night.
Old Jun 6, 2007 | 09:04 AM
Well, the first question seems to be a result of the main relay. These have been known to cause hot-start problems around the time your car was manufactured and the problem probably can be corrected simply by replacing this part which can be bought at a Honda dealer for about $50.
(i found that posted on a different site anyone know anything about it?)
Old Jun 6, 2007 | 09:07 AM
Default Re: 90 LS problems (jaysteven)
is there a way to check codes without having a scanner?
ZombieKing
10
Apr 22, 2014 11:09 AM
Meatwad1355
Jul 1, 2007 08:12 AM
OrangeBoost
Aug 1, 2006 05:13 AM
v00tecsi
Dec 24, 2003 02:54 PM
