90 integra
my wipers and water dont work for some reason....never had a problem i replace a few fuses then my wiper blades just stop working i have no i idea fuse is still good...
So you have checked fuse 16 - 20A, [hot in run] in under dash fuse box.
Did you actually test the fuse or just eyeball it, or replace it with a new fuse?
Did you test to see if there was power at the fuse, when ign. switch is in run position?
You will need to also test for power at the wiper motor and "Combination Light Switch" on the green/black lead, again with the ign. switch in run position then test for power on the blue lead at wiper motor with switch on low setting and then on the blue/yellow with switch on high.
Because the wipers do not work at all, [assuming] I would guess it is the wiper motor itself or possibly the motor ground, [black at the motor ] 94
splagga
Apr 15, 2015 11:57 AM
