90-91 integra vtec ?
Old Nov 21, 2005 | 08:41 AM
da6jdmteg's Avatar
Default 90-91 integra vtec ?
i just recently put my vtec in my 91 da. my b16 ecu was stolen. iwas just wondering if anyone had any ideas to run vtec besides the old toggle switch. im runnin the ls ecu right now. dont know much about it but is there a pin or anything to hook it up to????????? please help any ideas will help besides the toggle.
Old Nov 21, 2005 | 09:05 AM
mmuller's Avatar
Mad Scientist
Default Re: 90-91 integra vtec ? (da6jdmteg)
you need a vtec ecu.
Old Nov 21, 2005 | 10:23 AM
jdmcars.com's Avatar
The proper thing to do would be to get a correct ECU to control your VTEC as well as have the proper fuel mapping.
The other option would be to get a VTEC controller, and have the car properly tuned (on the dyno!)
There is an option other than the toggle switch, which again I would not recommend doing either the toggle or this beucase you are still not having the correct fuel mapping. However, you can get an RPM Activatived switch so that it switches at a certain RPM. MSD and others offer the product like so.
Old Nov 21, 2005 | 10:35 AM
mmuller's Avatar
Mad Scientist
Default Re: 90-91 integra vtec ? (jdmcars.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com &raquo;</TD></TR><TR><TD CLASS="quote">The proper thing to do would be to get a correct ECU to control your VTEC as well as have the proper fuel mapping.
There is an option other than the toggle switch, which again I would not recommend doing either the toggle or this beucase you are still not having the correct fuel mapping. However, you can get an RPM Activatived switch so that it switches at a certain RPM. MSD and others offer the product like so.</TD></TR></TABLE>
those are not really feasible options either since by buying a vtec controller youll spend the same or more money than just buying a vtec ecu.
Fuel Mapping is not nearly as important as the right Igntion timing, wich you cant unless the right ecu is used.
supergoob
Mar 14, 2008 04:52 AM
chivid
Aug 17, 2007 06:43 PM
nfinitecc
Nov 14, 2004 09:21 PM
UndergroundVR-4
Mar 14, 2003 02:58 PM
eg6madness
Mar 5, 2003 07:52 AM
