87 integra pgm-fi code 8/9?
87 integra ls
OK. last week i was coming off an off-ramp and my lights start dimming and my car dies. i called a guy who works with me (2 mins away) to give me a jump and he reverses the jumper cables and blows the main battery fuse. smart guy.
towed the integra to a honda/acura shop and he said the alternator brushes were worn, which is why the car died and the main battery fuse was blown because he reversed the jumper cables. had him fix the brushes and replace the main battery fuse
todays the first day i drove the integra and the pgm-fi light comes on. flashing pgm-fi on and off spontaneously. as its doing that, it feels like my car is "putting" or losing power, like its not getting enough fuel. it died once on the way home and the second time it died just as im pulling up to my driveway. i tried starting it and it turns over, everything works, it just wont start unless i give it 15-20 mins, then it dies again.
i checked the code and its throwing an 8 or 9.. im leaning more towards the 8 code. i cant tell because i cant get the thing to turn over. it seems like it almost does, then dies. any clues? tia
First, here are the codes.
CODE 0 =FAULTY ECU
CODE 1 =OXYGEN CONTENT (FRONT MANIFOLD ON LEGEND
CODE 2 =OXYGEN CONTENT (REAR MANIFOLD ON LEGEND
CODE3-5 =MAP SENSOR OR MANIFOLD ABSOLTE PRESSURE
CODE 4 =CRANK ANGLE SENSOR
CODE 6 =COOLANT TEMPRATURE
CODE 7 =THROTTLE ANGLE
CODE 8 =TDC POSITION
CODE 9 =NO.1 CYLENDER POSITON
CODE 10 =INTAKE AIR TEMP
CODE 11=IMA (86-87 LEDENDS ONLY)
CODE 12 =EXHAUST GAS RECIRCULATION (LEGEND ONLY)
CODE 13 =ATMOSPHERIC PRESSURE
CODE 14 =ELECTRONIC AIR/IDLE CONTROL (EACV OR EICV)
CODE 15 =IGNITION OUTPUT SIGNAL
CODE 16 =FUEL INJECTOR (INTEGRA ONLY)
CODE 17 =VEHICLE SPEED SENSOR
CODE 19=LOCKUP CONTROL SOLENOID VALVE (AUTOMATIC TRANS)(INTEGRA ONLY)
CODE 18=IGNITION TIMING ADJUSMENT
CODE 20 =ELECTICAL LOAD (INTEGRA ONLY)
Go double check you code. Becuase it says (if your right) you have a fulty sensore,
The code 9 No 1 position is the dizzy. You'll have to get a new dizzy (distributor)
zGo and double check and come back with the correct code please.
Thanks,
BTW: I onwed a 87 Integra ls (modified) then I bought a DA and sold it.
So I'm not just some guy talking out of no where. I owned the same car too.
CODE 0 =FAULTY ECU
Thanks,
Well, If its TDC Position,
It means (Kinda commen sence) Its not positioning right for TDC (Top Dea Center)
Which is when the #1 Cylinder is at the top of the block on its compression stroke
(Sry, I dont know how much you know, So I'm just saying)
Anyway, I'm not going to tell you something I dont know,
Go to http://www.g1teg.org
Register and ask them, they will help you very much,
I was on there for a year while I had by 87 ls, Which BTW was in the family for 15 years and I never had any problems with it, the I sold it,
and the new owner screwed it al up
(if he comes in here and sees this post
Anyway, Register at ww.g1teg.org and ask them, they wil help you with everything you need to know,
And BTW, Here is some G1 teg love for ya, (My old one)
The broshure9I have them in huge sizes)
And a Video of me in my 90 integra B18A1 (both cars about same mods,
During thise video) 55-110, I just walked it.
http://videos.streetfire.net/p...E1E08
Yes, I a picture *****,
Anyway, goodLuck man, I hope I helped
)Anyway, Register at ww.g1teg.org and ask them, they wil help you with everything you need to know,
IcantDo55
Sep 13, 2022 02:33 PM
