Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 Accord 2.4 no spark and u0107 code
Old 09-04-2018, 10:18 AM
IcantDo55's Avatar
Default 2006 Accord 2.4 no spark and u0107 code
So working on a car for a friend. Story goes that battery died so he installed new battery and than car did nothing. He found the main fuse had blown (still has not admitted to is but i suspect that the battery was put in backwards). Replaced fuse and now it turns over and wont start. I have checked, fuel pump does run and prime, and immobilizer "key" on dash light come on and goes off in a few seconds also checked power to coils and have none. I have ground but no power. I have checked all fuses for ignition and also swapped the ignition relay with no change in symptoms. Hooked up code reader and got U0107 , no idea if that has anything to do with it.
So if my guess is right, what blows up when a battery hooked up backwards in a 2006 2.4 auto accord.
Thanks!
IcantDo55 is offline
  • Ask a Question
Question Title:
Description:
