8500
Old May 9, 2002 | 07:13 PM
lsteggy's Avatar
Default 8500
i was racing against a hatch tonight and i was in third gear i went to shift to fourth and it slammed it in second on accident. i reved all the way up to 8500. i have a old *** motor with 110k on it. it runs fine as of now but my brand new clutch feels a lil bit different. the only mod i have is intake. i was just wondering what kind of damage i could have done thanks.
Old May 9, 2002 | 07:22 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: 8500 (lsteggy)
8500 isn't bad... unless you're not in a GSR...
Old May 9, 2002 | 07:26 PM
lsteggy's Avatar
yeah thats the problem i have a ls
Old May 9, 2002 | 07:33 PM
lsteggy's Avatar
the rev limiter never kicked in. it went all the way to 8500
Default Re: 8500 (krrrrrrzyrebel)
crap! i think the rev limiter should have doen something because there have been times when i just got my car, and i did my first downshift, i was @ about 6k in 3rd, and i downshifted to 2nd, the rpm shot off but it just stopped @ 7200...thank god
rev limiter is disabled in neutral
Old May 9, 2002 | 07:53 PM
Taiwanze7's Avatar
Default Re: 8500 (dLo GSR)
rev limiter is useless when the wheels are going faster than the engine
Old May 9, 2002 | 08:15 PM
lsteggy's Avatar
yeah does anyone know what kind of damage it could have done??????
Old May 9, 2002 | 08:36 PM
bocian's Avatar
if your car is running fine the probably nothing is wrong, but if it idles unevenly, you might have melted valves, if its running like real crap or not running at all, you bent your valves. i did the same, from 5th to 2nd instead of 4th, one of the springs from my clutch busted and my tranny gave out but the motor was/is fine! went to about 9200 rpms (thank god i have a gsr)
hth
Old May 9, 2002 | 08:45 PM
MaskedAP1's Avatar
how come? u just had an intake rite?
Old May 9, 2002 | 08:47 PM
Default Re: 8500 (RedNoise)
there is no rev limiter for neutral!!!!!
Old May 9, 2002 | 08:51 PM
bocian's Avatar
Default Re: 8500 (Taiwanze7)
Old May 9, 2002 | 08:56 PM
threatcon13's Avatar
New User
Default Re: 8500 (bocian)
don't ever think that the rev limiter applies when downshifting because it doesnt.
Old May 9, 2002 | 11:05 PM
akhom's Avatar
Default Re: 8500 (ALLMOTORDC2)
Hey all you people, Rev Limit is a fuel cut off. It cuts the fuel so it will not let you accel pass red line. But it will not stop the tranny from pushing the motor pass redline in cases of a 3rd at redline to 2nd Shift. Understand this and stop wondering where the Rev limiter when.
~Andy~
Old May 9, 2002 | 11:14 PM
B00ST2nR's Avatar
Exactly. It doesn't matter if you have a rev limiter or fuel cutoff. If you're goin high speeds, and you jam it into a much lower gear than you're suppose to, it has no choice but to rev that high at that speed...
If you were in a GS-R and revved to 8500rpm, you shouldn't worry... but I just read it over and you said you did it in your LS. There might be a problem so get it checked before you regret it...
Old May 9, 2002 | 11:29 PM
tonydatyga's Avatar
Default Re: 8500 (b18c1 dc2 R)
you should already regret it
Old May 10, 2002 | 01:26 AM
LOwrestling2001's Avatar
Default Re: 8500 (tonydatyga)
whenever i misshifted in my old car, i woudl see hte revs climbing and just press the clutch in...c'mon now guys...
Old May 10, 2002 | 09:24 AM
TGUNNER's Avatar
Default Re: 8500 (LOwrestling2001)
BENT VALVES....
Old May 10, 2002 | 11:10 AM
scribnits's Avatar
Yes there is...Ive hit limiter in neutral many times...for no apparent reason other than I love that sound.
Old May 10, 2002 | 11:44 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: 8500 (DC24U2NV)
how bout you dont be stupid when you are going fast.. wtf i have never ever shifted from 3rd to second on accident.. wtf.. and 5th to 2nd?? WTF!? You have to actually try to do that.. wtf were you thinking? roflmao!!!
Old May 10, 2002 | 11:56 AM
lsteggy's Avatar
Default Re: 8500 (GSR-OwnzJo0)
its was an accident i would never do something like that on purpose. i guess the adrenaline was just pumping to much and i made a mistake.
i been driving around a little bit and everything seems fine. maybe i got lucky and nothing is messed up
Old May 10, 2002 | 10:29 PM
bocian's Avatar
hey guys, get a load of mr. perfect. ill be rotflmao when this happens to you. i dont wish you any bad luck but dont cross the bridge until you get to it. just a thought
[Modified by bocian, 2:31 AM 5/11/2002]
Razr2
15
Jan 1, 2008 10:24 PM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
hondadriver
Mar 10, 2006 12:51 PM
sheBangZ
Sep 28, 2005 04:58 PM
psilo
Jan 4, 2005 03:05 PM
