6x9 speakers in the back of an integra, possible?
Old Sep 14, 2003 | 03:26 AM
AspectIndustries's Avatar
Default 6x9 speakers in the back of an integra, possible?
I'm sure this will be good in the Audio section, but since I'm really in need of asking integra owners. - Thanks:
Integras have 6 1/2 inch speakers all around,
but I'm curious has anyone done this and putted 6x9's in the back? and also, if so, is there an adapter where i can fit these speakers in?
Because, I looks in the back and im sure there is LOTS of room to fit a 6x9 in, easy.
Any feedback will be nice. THanks.
Old Sep 14, 2003 | 07:12 AM
fivespeedintegra's Avatar
Default Re: 6x9 speakers in the back of an integra, possible? (synik)
the looks of the back are deceiving....
yes, the speaker grill back there is huge, but if you actually look behind it, there isn't a ton of room (just enough for a 6.5" round).
i'm not saying it can't be done, but i am saying that it won't be easy or fun.
Old Sep 14, 2003 | 07:40 AM
BolivianDc2's Avatar
Default Re: 6x9 speakers in the back of an integra, possible? (fivespeedintegra)
i want to try to put 6x9s in my integra, 6.5s suck in the back
maybe you could cut into the rear cover and mount them there. but that won't work for people w/ stripped interior
Old Sep 14, 2003 | 07:50 AM
Default Re: 6x9 speakers in the back of an integra, possible? (Bolivianstrtwpn)
ehhh....i just have a big 12" vega sub in the back....screw weight reduction
Old Sep 14, 2003 | 08:21 AM
ebelp's Avatar
Yes, it can be done. You have to do a lot of hacking and cutting of the inner metal though.
Old Sep 14, 2003 | 08:25 AM
B U N M A N G O's Avatar
Default Re: 6x9 speakers in the back of an integra, possible? (ebelp)
yes of course it's possible... in a sedan
actually my friend had Infinity Kappa 6x9's in his Integra coupe, so it can be done.
Old Sep 14, 2003 | 08:34 AM
I guess, ill try and give it a shot. -
My brother had done and putted the 6x9's in the rear cover. Very nicely done, but seems to me as if i rather dont want to leave the back side panel empty, when i can cleanly hide the speakers. -
Either or, i will try to fit this sucker in there. - . Any other had done this to their integra? Pics? Thanks bunches..
Old Sep 14, 2003 | 09:12 AM
ucantcatchmefoo's Avatar
hey dude what i did was cut one of the small plastic brkts of the factory mounts, and basicaly used the factory mount spots, granted i did have to drill pilot holes lust afew milimeters away from the originals. I have three mount points on my rear 6x9's.
Old Sep 14, 2003 | 09:15 AM
you know the only thing that sux is the entire friggin 1/4 trim panel has to come off, that means rear seat, seat belts, rear body int trim, and friggin on and on. I drive a 96 ls so it should work on yours too.
Old Sep 14, 2003 | 09:20 AM
sjteg's Avatar
Default Re: 6x9 speakers in the back of an integra, possible? (ucantcatchmefoo)
you could also custom fit them onto the cargo cover. I had that done for a while and it sounded pretty good. I took them out after i took out my seats though.
Old Sep 14, 2003 | 10:53 AM
92AztecGsr's Avatar
my 4 door gsr has 6x9's under the grills in the back windows, Im not to sure if its stock or someone did it but there was no mod. to the vehicle???
Old Sep 14, 2003 | 10:58 AM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucantcatchmefoo &raquo;</TD></TR><TR><TD CLASS="quote">you know the only thing that sux is the entire friggin 1/4 trim panel has to come off, that means rear seat, seat belts, rear body int trim, and friggin on and on.</TD></TR></TABLE>
heh, that takes 20 minutes.
Old Sep 14, 2003 | 01:48 PM
ar0nic's Avatar
if your trying to get more low end out of your back speakers consider a component set with mids and what not for the car..unless you dont have subs in the back or else it wont sound quite right..then you get to hackin away at your car
Old Sep 14, 2003 | 01:52 PM
Jet Black's Avatar
I've done it.
Its not easy or fun...but its quite possible.
With NO permanat mod to the car. There is a SHITLOAD of space behind the rear pannels. I made a mount out of wood and cut it to hold the speaker in. Worked great...my only mistake was that I never made a barrier between the rear of the speaker and the front, so I'm not getting any bass out of em...I'll have to take it apart and make some sort of baffle when I get a chance.
Old Sep 14, 2003 | 09:32 PM
Default Re: 6x9 speakers in the back of an integra, possible? (Jet Black)
O_O i did it.! Was an ez task, but instead i just mounted them to the back rear covers. AND did i say WOW!? Looks VERY VERY NICE! and the sounds is really impressive. I live it. - the back rear covers has two metal bars in them, which the speakers lay exactly between them. Good support on them! Thanks for advices though. -
Old Sep 14, 2003 | 10:00 PM
JaY-R's Avatar
yes.. it's doable
Old Sep 15, 2003 | 03:34 AM
00 FBP ItR's Avatar
It fits w/ barely any work involved, all you need are self tapping screws.
Here a pic of mine mounted.
https://honda-tech.com/zerothread?id=612820
Old Sep 15, 2003 | 06:31 AM
S1ERRA's Avatar
Default Re: 6x9 speakers in the back of an integra, possible? (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote"> It fits w/ barely any work involved, all you need are self tapping screws.
thanks for the info and pic! i just bought a pair of eclipse 6x9 3 way speakers and i'm going to mount them in there too...
Old Sep 15, 2003 | 10:58 AM
sjteg's Avatar
https://honda-tech.com/zerothread?id=612820</TD></TR></TABLE>
the 6.5 mount is big enough for the 6x9 speaker? wow looks like i might do this.
Old Sep 15, 2003 | 10:46 PM
Default Re: 6x9 speakers in the back of an integra, possible? (sjteg)
I will try to get an image of mines tomorrow. - no from the side, but back covers. ( I bump my speakers FULL BLaST! ) scarey for them to fall..in there..
Old Sep 16, 2003 | 12:40 AM
00 FBP ItR's Avatar
remove the whole 6.5 pod, and then some self tapping screws and you're done.
when you take off the Whole panel its much easier to access.
Old Sep 16, 2003 | 06:27 AM
Xsi's Avatar
Xsi
Does the speaker sound any good mounted like that? It looks like it's only touching sheet metal in a couple of spots and has free air around most of it?
Old Sep 16, 2003 | 06:45 AM
Default I just instead putted the 6x9 in the back covers.
Here's what i decided to do. Looks nicers and maybe sounds better? Wells, heck IT SOUND D@MN NICE. - Just need to put on my speaker grill, then im set to go. The speaker fits perfectly between the two metal bars ( good for support ) and no rattle whatsoever. Sounds VERY VERY sharp and clean.
Old Sep 16, 2003 | 09:18 AM
Chris's Avatar
Default Re: I just instead putted the 6x9 in the back covers. (synik)
If anyone wants to put the 6x9 on the rear shelf, and retain their rear shelf.. I think I have 2 to sell 1 for sure... IM me
Old Sep 16, 2003 | 10:09 AM
IntEGNYC's Avatar
better sound imaging bouncing off the rear glass
