5-lug conversion
Old Jun 16, 2004 | 11:51 AM
Project X's Avatar
Default 5-lug conversion
Does anyone know if the wheel track will change if going to the ITR 5-lug conversion? Currently, all regular Tegs are +45mm and ITR is +50mm offset. Will going to 5-lug changes that?
Please note that the wheel track I'm referring to is the distance between the center of the left and the right wheel.
Old Jun 25, 2004 | 04:44 PM
Project X's Avatar
Default Re: 5-lug conversion (Project X)
Anyone?
Old Jun 25, 2004 | 05:56 PM
esponet's Avatar
not 100% sure but i think that being the ofset is different then the wheel track will stay dsame. but the actuall hub placing, i think the R is abit more wider than the regular ones.
someone correct me if i'm wrong.
Old Jun 28, 2004 | 11:19 AM
Project X's Avatar
Default Re: (esponet)
So, after the 5-lug conversion, do I get wheels with 45mm or 50mm offset in order to achieve the factory spec?
Old Jun 28, 2004 | 11:28 AM
Kendall's Avatar
If you swap to the 5 lug, then you need to get wheels with an offset for the ITR.
Old Jun 28, 2004 | 11:33 AM
CNSK's Avatar
Default Re: (Kendall)
I changed my wheel nut and I had to pound out the hub off. I wonder what if I just buy a Type r hub and 5 lug rotors and make it into a 5 lug type R. Is that possible?
Old Jun 28, 2004 | 12:44 PM
Project X's Avatar
Default Re: (DrMartin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin &raquo;</TD></TR><TR><TD CLASS="quote">I changed my wheel nut and I had to pound out the hub off. I wonder what if I just buy a Type r hub and 5 lug rotors and make it into a 5 lug type R. Is that possible? </TD></TR></TABLE>
You need ITR calipers too becuz they are bigger. I remembered seeing a site that shows how to use ITR calipers and rotors without changing the hubs, etc. It required something like shaving few millimeters off the back of the caliper brackets.
Old Jun 29, 2004 | 07:06 AM
CNSK's Avatar
Default Re: (Project X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">
I think you need to change out the hub because you will need a 5 lug hub. I got a pair of 96 jdm r calipers actually the whole front suspension but only 4 lug from a 96 though. No rear So I figure maybe I just change the hub out along with rotors then Ill be straight....but will see....
miamirice
46
May 3, 2011 06:58 AM
S2Integra
Mar 16, 2010 10:37 AM
shaggyeg6si
Apr 21, 2008 10:41 AM
camil212
Jan 28, 2007 07:20 PM
Mr. Softee
May 2, 2003 01:30 PM
