i got 195/50/15 tires and wanted to know if i can go 205/50/15.
Re: i got 195/50/15 tires and wanted to know if i can go 205/50/15. (tdo)
first of all what kind of car? ive got 205 50 15 on my 00 civic and it rubs once in awhile but its not bad at all. id say got 205 45 15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo »</TD></TR><TR><TD CLASS="quote">i found some 205/50/15 and wanted to know if this is ok to get?
i got 195/50/15 right now.</TD></TR></TABLE>
what kind of car do you have most of all?
any type of suspension mods?
what type of tires are you looking for?
Re: i got 195/50/15 tires and wanted to know if i can go 205/50/15. (lazie)
i got a eh2 and my suspension is almost stock height.
i also have a h22 sitting in front so that might make a little difference.
but anyways i just wanted to know because i found a set of tires for pretty cheap and wanted to get them for later uses, but they're 205/50 and i have 195/50 right now.
Farts in the shower
I would stick with 195/50/15 but if you want to run a wider tire and your rims are capable of it then get the 205's but you might rub even on stock suspension in which case stick with the 195's .
edit: try this out: http://www.miata.net/garage/tirecalc.html
their 205mm wide and 102.5mm tall, if you have 102.5mm of space between your wheel and your fender then sure they should be fine, i never had any problems running a 205 width tire its all in the height if you can fit it, it should be fine
FAWKeveryb0dy
08-14-2006 12:44 PM
Powered By Garrett
03-07-2005 08:13 AM
