2 stage ignition module?
Old Jul 31, 2003 | 07:46 PM
SIanara's Avatar
Default 2 stage ignition module?
i have an msd ignition in my 96 4dr GSR... and idk wtf the 2 stage mod. means... i think it has something to do with settings....and a somewhat of a plugg and play deal...it has these little fuse like looking plugs with #'s on them... i think that there' intended to replace the others for a different setting.. any one have a word on this?!!!!! priciate it!!!!!!!!thanx
Old Jul 31, 2003 | 07:52 PM
mr.beeks's Avatar
Default Re: 2 stage ignition module? (GSR4340)
the concept is simple, it is used for drag racing.
most drivers out there over rev on the take off and if you dont have enough
traction you will sit there while the next man is way ahead.
so the stage two helps you on controlling this for you.
so you set your first rev limiter to 4500 for your take off so you let off the gas and shift.
and the redline limiter at lets say 8000.
and you will be improving your times as well..
Old Jul 31, 2003 | 08:48 PM
SIK IN DA HED's Avatar
New User
the 2 step helps you set a revlimiter and a staging revlimiter for launches
RollingSuicide
Mar 21, 2006 04:49 PM
SIanara
Dec 4, 2003 02:12 PM
kentucky accord
Dec 11, 2002 09:08 PM
HotRodTeg
Sep 30, 2002 08:48 AM
speedymon
May 8, 2002 04:22 PM
