2 step ign, recommendations.....
i am trying to decide on a 2 step rev limit to use in the water box and while staging. i want one that i can set a low limit for the staging/burnout and a high limit for shifting. or if i can get by with just the stagin/burnout(low) limit, i will go that route. thanks for any input.
btw, iginition is totally stock w/ internal coil
the hondata is always a good option but i am trying to do a low budget thing although i would like to see one of those in the future.
any advantages of the digital over the 6AL?
thanks. i am a retard when it comes to ignition.
MSD carries a two stage switch you can use.. I don't believe any of the MSD 6a or 6al have a two stage.. It'll be way cheaper than get any of the ignition boxes, especially if you don't need them.
When it comes to digital ignition.. I believe for the most part.. you need to be running digital ignition before you can use that... I believe talons/eclipses can use this system.. But I could be wrong.
Way OT: But, DAMN! Your car is stripped! *Talking to KY Accord*
If you don't want the Hondata, then the only other option is MSD. You can get them for cheeeap, used...so look around.
hey thanks for the relpies, i checked with a couple local racers and they say the same thing. looks like its going to be msd 6AL w/ 2 step module for me.
thanks again!
thanks again!
digital 6 comes with 2/3 step built in, and u dont need pills to use it, just uses pots/dials
the 6AL (L=limter) u need the seperate 2/3 step module, AND pills.
