2 part question
Old Jul 28, 2008 | 10:55 AM
steveharrmr23's Avatar
Default 2 part question
what is the result of under torqing my head bolts
what is the result of over torqing my head bolts
Old Jul 28, 2008 | 11:04 AM
PalmyBlueB20's Avatar
Default Re: 2 part question (steveharrmr23)
if you under tight them they'll probably unloosen up which could cause a disaster
if you over tight them ur head can crack
thats what i think lol
Old Jul 28, 2008 | 12:50 PM
vtecb18c's Avatar
Default Re: 2 part question (PalmyBlueB20)
if you over torque the head studs it will "squirt" the compression rings on the headgasket into your cylinders....get a haynes manual it has all the torque specs
Old Jul 28, 2008 | 01:29 PM
Default Re: 2 part question (vtecb18c)
i have a manuel but i do not have new head bolts and i need my car asap does anyone know how much old stock head bolts should be torqued at
Old Jul 28, 2008 | 01:30 PM
vtecb18c's Avatar
what motor?
Old Jul 28, 2008 | 01:46 PM
vtecb18c's Avatar
CYLINDER HEAD BOLT TORQUE SPECS (tightening) / (loosening)
8, 4, 2, 6, 10 <---intake order 3, 7, 9, 5, 1
7, 3, 1, 5, 9 <---exhaust order 4, 8, 10, 6, 2
Torque in steps: 22ft-lbs (264in-lbs), Then to 63ft-lbs (756in-lbs) (final spec) 94+ Teg
Torque in steps: 22ft-lbs (264in-lbs), Then to 61ft-lbs (732in-lbs)(final spec) 90-93 Teg / B16's
Old Jul 28, 2008 | 02:47 PM
J. Funk's Avatar
You probably don't want to find out. Torque them to the right specs.
Old Jul 28, 2008 | 04:19 PM
steveo135's Avatar
Default Re: 2 part question (J. Funk)
If you overtighten them you get mad extra vtaks...
^ false information
If you look in the integra forum FAQ you can find the correct torque specs and you'll be fine... but if you want an answer to those two questions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveharrmr23 &raquo;</TD></TR><TR><TD CLASS="quote">what is the result of under torqing my head bolts
what is the result of over torqing my head bolts</TD></TR></TABLE>
TROUBLE
Old Jul 28, 2008 | 08:29 PM
Default Re: 2 part question (steveo135)
i am asking because i know that some have reused the stock ones and i know the other half use new i am trying to find out from someone who reused the stock ones how much the final torque was
Old Jul 30, 2008 | 06:11 AM
steveo135's Avatar
I reused the stock ones and torqued them the same as if i had gotten new ones
Old Jul 30, 2008 | 07:52 AM
did you have any problems
anothersickhatch
12
Jun 10, 2004 02:26 PM
NOOTRON20
Oct 11, 2003 10:18 AM
