1991 b18c1 Integra Max Hp?
Old 02-23-2009, 11:27 PM
New User
b18c1Acura91's Avatar
Default 1991 b18c1 Integra Max Hp?
Im trying to build my 1991 integra, when I bought the car it had a b18c1 gsr block and a b18a1 head, Thats the way it still is. Whats the best way to get a big Hp gain without a turbo.. Any Ideas?
Old 02-24-2009, 01:37 AM
TOO MUCH TORQUE's Avatar
Default Re: 1991 b18c1 Integra Max Hp?
supercharger
Old 02-24-2009, 04:13 AM
MD426's Avatar
Dump massive amounts of money into it, it's the only way.
Old 02-24-2009, 07:59 AM
hondahead_dave's Avatar
so you have an ls head on a gs-r block? I didn't know people did that.
Old 02-24-2009, 08:59 AM
New User
Yea the I didnt thank ppl did that either, But When a bought the car thats how it was,
Old 02-24-2009, 09:05 AM
I'mEK's Avatar
Well for the start you'll have to get rid of the b18a1 head and get a b18c or any b16 head. You'll get more more hp.
Why would any body put together a motor like that? Ls head on a Gsr block!
Old 02-24-2009, 09:20 AM
seanbev24's Avatar
Don't get a B16 head unless you plan on either changing the pistons or going turbo, you'll have lower compression than a stock gsr.
I'm guessing that motor is like that cuz the previous owner built an LS/VTEC and threw that crap together hoping someone would buy the DA.
For now you should be focused on finding a GSR head and a better tranny (b16 or b17) that will probably get you 40 hp along with better gearing. Plus I would be carefully inspecting the work that was done by the previous owner.
Old 02-24-2009, 09:25 AM
OOOtony's Avatar
i was wondering whats the diff. between the b17 and b16 cable tranny?
just the final?
Old 02-24-2009, 09:39 AM
New User
Im ordering some pop top pistons for the gsr block.. it claims 12:1 comp/ratio with the vtech head so im guessing that the dome pistons will give me about 11:1 comp/ratio with a b18a1 head, The type R teg has something like 11:1, So by doing pop top pistons, do you thank ill gain some good hp?
Old 02-24-2009, 09:42 AM
seanbev24's Avatar
I forget the gearing differences there are gear charts floating around on the interweb. Both are good trannies, but the b17 ys1 was never available with LSD like the jdm b16's.
IMO the best cable tranny is the 92-93 Xsi YS1 with LSD if you can find one. You get lsd plus the bigger input shaft and many shared characteristics of all 92-01 b series trannies.
Old 02-24-2009, 09:52 AM
seanbev24's Avatar
To the OP... are you trying to build some kind of all motor set up and keep the b18a head?
Old 02-24-2009, 09:54 AM
Daisy... Daisy...
Dogginator's Avatar
Run a compression and leakdown test to assess the relative health of the engine. Why did the original owner swap the VTEC head? You could have a true frankenmotor. How do you know that the bottom end internals are from a stock B18C1?
dmpd_ef's Avatar
im not one to judge a book by its cover but im guessing that your kinda new wrenching on Hondas
if you want my opinion, look for a gsr head, and a cable b16 or b17 tranny (dont get your hopes up in finding an lsd one for cheap either) throw on a header, exhaust, intake and other little stuff and see if you like driving it like that, most people do and theres no need to have to tear down the entire block to put in some pistons that you probably coulda done without.
Old 02-24-2009, 09:22 PM
New User
The block is stamped with b18c1, that all im going off of. And the original owner is a dumbA$$, I cant find a dohc v-tec anywhere!!
Old 02-24-2009, 09:25 PM
New User
Yea i am kinda new to the hondas but my teg has intake, exhaust, etc. **** like that, But im looking for around 270-275 hp out of this motor when im done, Maybe even with that shity ls head..
Old 02-25-2009, 03:54 AM
Daisy... Daisy...
Dogginator's Avatar
Good luck with that normally aspirated. 200 whp is a typical goal for normally aspirated.
Regarding the block stamp, that just means the block was from a B18C1. WHo knows what the previous owner did. He could have swapped the pistons, rods, and crank. You do not know until you look. Sorry.
Old 02-25-2009, 09:08 AM
slammedNslowLS's Avatar
go to JG Engine Dynamics website and just buy their all motor long block for $4700.00. A1 block and GSR head i think is what they use, anyways they say 260hp+. Theres your long block. Then buy a B16 tranny and then find else what else you need and go from there. I mean no disrespect but you got some learning to do before reachin that amount of power all motor with your setup and no knowledge of what to do. Everyone can point in the way to get started but thats as far as it goes. Best to buy on already there and button it up
Old 02-25-2009, 12:10 PM
weavertime1's Avatar
Good luck making anywhere near those numbers naturally aspirated even with a VTEC head...
Old 02-25-2009, 01:15 PM
Vietnamese!
ALLxMOTOR EG's Avatar
x2
Old 02-25-2009, 08:22 PM
New User
Lol Well wtf!! Ive done alot of research, But what can I say, Im tryin....
Unsought Devil
10
11-23-2006 10:21 AM
myDC4rox
11-29-2004 06:23 AM
dAndOg130
10-08-2003 11:37 AM
BI8B
09-11-2003 08:38 AM
CBR
08-19-2002 07:18 AM
Quick Reply: 1991 b18c1 Integra Max Hp?
