02 sensor wire in ECU?
Old Oct 19, 2001 | 03:07 PM
Tony the Tiger's Avatar
Default 02 sensor wire in ECU?
I have a 1995 GSR, I I couldn't find out which wire in the ECU is the 02 sensor wire! I have the J&S installed, but the J&S wiring diagram didn't specifically indicate where the wire was located.
I know some of you must have an air/fuel meter tapped in the ECU instead of the 02 sensor. Can anyone help me out?
Thanks.
Old Oct 19, 2001 | 05:27 PM
FSTASNTZ's Avatar
Default Re: 02 sensor wire in ECU? (Tony the Tiger)
In my 1997 ITR it is a white wire with a silver band on it. Tap a voltmeter into it and see how the voltage is as the car idles, WOT and as you cruise.
Jason
Old Oct 19, 2001 | 06:24 PM
udctown's Avatar
New User
i have a 96 gsr and it is the pure white wire. no silver on it or anything. don't listen to the haynes manual. the schematics in that are wrong believe me. i'm a computer engineer and i know how to read schematics and it told me something totally different when i referenced a helms manual. which rocks by the way.
peace.
Old Oct 21, 2001 | 03:41 PM
Default Re: 02 sensor wire in ECU? (udctown)
I actually need the '95 GSR (OBD-I) O2 sensor wire...
I spliced into the white wire and I get no reading. Remeber that '96 GSR's are OBD-II!
Thanks!
Old Oct 21, 2001 | 05:37 PM
Anyone?
Old Oct 21, 2001 | 06:20 PM
FAST94GSR's Avatar
New User
can you read the voltage off that wire? I have obd 1 too and I believe its a white wire. Unfortunately I don't have my car here to double check, I'll get it back tomorrow then I can tell ya for sure.
What ya dynoeing at these days? Your car looks exactly like mine btw! Do you have a full bodykit or just the WW front lip spoiler with the lower side mouldings painted to match the car?
Old Oct 21, 2001 | 06:48 PM
stick's Avatar
Default Re: 02 sensor wire in ECU? (FAST94GSR)
sorry tony i cant answer ur question about the o2 sensor but to answer fast94GSr.
he posted his dyno about 4-6 wks ago and it dynoed 220 hp to the wheels.
i have the same color and I want my car to run like his.....
Old Oct 21, 2001 | 07:06 PM
FAST94GSR's Avatar
New User
Default Re: 02 sensor wire in ECU? (stick)
heh all it takes is money bro! I'm gonna do a search for that graph.
Old Oct 22, 2001 | 05:34 PM
HKxBlur's Avatar
To the above post, the o2 sensor sends out a voltage based upon the air/fuel reading.. Poorman's a/f ratio gauge is just a voltmeter displaying the mV's..
Old Oct 22, 2001 | 06:47 PM
randomwalk101's Avatar
Anyone?
D-14
Old Oct 22, 2001 | 08:14 PM
teg92's Avatar
Default Re: 02 sensor wire in ECU? (randomwalk101)
If you still haven't gotten your answer I recommend emailing one of the most resourceful people I know of integras. his email is g2guru @ hotmail . com (to avoid spam). He visits on here as well name dplatt.
slwazgsr
Sep 30, 2002 04:19 PM
slwazgsr
Sep 30, 2002 02:48 PM
Stew Pidasso
Apr 8, 2002 06:46 PM
H23 Power
Sep 26, 2001 08:45 PM
Flamenco-T
Jul 7, 2001 04:38 PM
