Wiring schematics or wire color breakdown of a 96 GSR? (schematics)?
Guys,I'm putting in the afc-circuit on my car but need the help on figuring our what color some of the wires are on the ECU, does anyone know a website that gives a diagram or schematic for a 1996 obd-2 gsr ecu? TIA, i already did a search but no results BTW, id there isn't a diagram would somebody know what the underlined ............
Yellow wire to = Output to ECU
Orange wire goes to = Input from MAP sensor
Red wire to= +5 volt suppy (MAP supply)
Black wire to = ground
o2 Board:
Brown wire to = to ECU, second o2 sensor
Blue wire to = Input from first o2 sensor
Green wire to= +12 volts, switched
White wire to= 2nd o2 sensor ground
o2 Board:
Re: Wiring schematics or wire color breakdown of a 96 GSR? (schematics)? (xdsmguy)
to be completey honest, you're just making it harder then it should be...pull the plugs from the ecu, and just do it....don't go by the colors of the wires because many have the same colors but different thickness of each color on the wire...(did that make sense? i'm tired) http://www.apexi.com good luck
Re: Wiring schematics or wire color breakdown of a 96 GSR? (98civicEX)
sorry guys,
I bought a circuit that mimics the AFC, not the actual AFC itself,
it's the one that filetofit makes,
BTW, thanks for helping me out,
I'm glad you love your Helm manual BTW, thanks for the advice
Re: Wiring schematics or wire color breakdown of a 96 GSR? (Arturbo)
damn now are all Honda-forums this uptight? even the damn moderators?
I just asked a simple question regarding some wire colors, my local automotive shops does not have any helms manuals, all they have are the basic Chilton's manual and they don't have the wiring diagram for the ECU on them, I just ordered a helms offline from Amazon.com but I didn't feel like waiting another week to have my car running right and nobody can look in their Helms for me to look up 4-8 wire codes? That's pretty shitty, I thought superhonda was bad, but some people just want to prove how little people they want to help, sorry i'm not a honda gods like you two and have every single damn manual for all my my vehicles, but one day you guys will need the help, whether it be in automobiles or in life and I hope I'm there to turn you down or brush you aside as you've done to me Afterall the forums are for help aren't they?
Re: Wiring schematics or wire color breakdown of a 96 GSR? (xdsmguy)
Wow, I didnt think I would offend you with my simple comment. My intention was not to offend you in anyway and Im sorry you took it as that.
But I cant help you because, for one, Ive never installed the Apex unit. If I gave you info I would be lying to you, and I dont want to give you false info.
art
art
Re: Wiring schematics or wire color breakdown of a 96 GSR? (Vert)
bumping this up
first off, public apology to Art and others
second, VERT
Could you tell me exactly what color wire on the map sensor is exactly what?
= Output to ECU
=+5 volt suppy (MAP supply)
= ground
o2 Board: and what color wires are......on ecu
what color is the --- Input from first o2 sensor
honda-tech is
[Modified by xdsmguy, 2:00 AM 10/1/2002]
second, VERT
= Output to ECU
= ground
honda-tech is
slammedz6ef
02-15-2008 07:46 AM
AdamITR
05-14-2003 05:44 PM
