OEM bearings with Aftermarket rods?
I'm gonna be buying some OEM bearings from Len sometime soon
i just want to know since that i am swapping rods will the size of the bearings change cause the rods changed
Re: OEM bearings with Aftermarket rods? (HypeR1004)
Yes,
You will have to measure the inner diameter of the rods big-end so you can size your bearings accordingly.
-Brandon
-Brandon
This might be useful info : https://honda-tech.com/zerothread?id=715490
Re: OEM bearings with Aftermarket rods? (Pondus)
Yup, just the post to refer to. I would recommend ONLY honda rod and main beaings, as you can get exactly the tolerance you want! Sure, other bearings cost less, but you don't see the V8 guys resizing thier rods and mains to fit those, now do you? (ie. Eagle and many other manufactures fit V8 rods and cranks to fit Honda bearings).
Location: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Re: OEM bearings with Aftermarket rods? (DavidR)
nothing beats OEM stuff (Bearings, seals, gaskets, blah blah)
