where is the airbag module or brain located?
Old 08-28-2004, 02:08 PM
lakerschamp2000's Avatar
Default where is the airbag module or brain located?
I need to remove it, i heard it locate somewhere under the dash but couldn't find it. please help.
Old 08-28-2004, 02:13 PM
Will you make something up for me please?
shamoo's Avatar
Default Re: where is the airbag module or brain located? (lakerschamp2000)
It's not anywhere near the dash.
In a coupe, it's on the passenger side where the back seat passenger would be sitting. To the right is the plastic panel (the one where the speaker grill is attached to).
That entire panel has to be removed, it's a pain because it goes all the way back into the trunk. Right in front of the speaker is the airbag module. I'll see if I can find a pic for you.
EDIT AGAIN AGAIN : No idea where it is on a sedan though.
EDIT AGAIN: I found the better pic. It's that grey box thing that the arrow is pointing at.
Old 08-28-2004, 03:29 PM
Dan GSR's Avatar
Default Re: where is the airbag module or brain located? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">It's not anywhere near the dash.
acutally that is the brain for the ABS
the brain for the air bags , is behind the radio area, there is a large yellow plug in it
it will be covered with a plastic case
Old 08-28-2004, 03:34 PM
shamoo's Avatar
Default Re: where is the airbag module or brain located? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">acutally that is the brain for the ABS
it will be covered with a plastic case</TD></TR></TABLE>
Blah! You sure? Damn, I haven't looked in an Integra in a while. Sorry for posting wrong info then.
Old 08-28-2004, 03:37 PM
Dan GSR's Avatar
this is the main plug that goes into the airbag module
follow the plug and you'll find the brain
all yellow colored plugs have to do with SRS
Old 08-28-2004, 07:41 PM
thanks a lot guys for the help.
93dagsr
01-22-2008 10:31 AM
M-EJ1
30
06-30-2006 09:07 PM
5ive19-EH3
01-08-2006 05:53 PM
mykal
13
09-30-2004 09:46 AM
Jmorin
11
02-19-2004 04:35 PM
Quick Reply: where is the airbag module or brain located?
