How do you have the valve cover so you can adjust the cam gears
Old 04-25-2004, 05:38 PM
quicksol95's Avatar
Default How do you have the valve cover so you can adjust the cam gears
How do you have the valve cover so you can adjust the cam gears?
LIke do you have it cut ?
Thanks
Old 04-25-2004, 05:46 PM
W C L's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (slowsohccivic)
unless u want to take i off everytime to adjust it
Old 04-25-2004, 05:51 PM
quicksol95's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (W C L)
do you cut whole where the cam gears are in the valve cover and the timing pulley cover or do you just cut the part away from the valve cover that covers the cam gears up
if anyone has any pics it would be nice
Old 04-25-2004, 10:03 PM
screech's Avatar
you can get it "moon cut" i believe is the term
got this pic off ebay but you get the idea
Old 04-25-2004, 11:35 PM
Toda Built's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (screech)
I just used a whiz wheel and cut off the side of the vavle cover. It is'nt the prettiest job but it was free and gets the job done
Old 04-26-2004, 05:53 AM
b16_madman's Avatar
i guess it's just a hole cutter, but what do you use to get the nice moon cuts? dremel and patience? sorry, i don't have lots of tools to know
Old 04-26-2004, 07:35 AM
realfasthonda's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (B16_madman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">i guess it's just a hole cutter, but what do you use to get the nice moon cuts? dremel and patience? sorry, i don't have lots of tools to know</TD></TR></TABLE>
just put the the valve cover on the motor and mark with a pencil the middle and the edges of the cam gears take it off use a compass and draw the half circles, then with a dremel cut em and sand smooth
Old 04-26-2004, 07:45 AM
Maddox's Avatar
The way that they make the "Moon Cut outs" is on a Mill, do it the cheap way, get a cut off took and cut off the Cam gear side of the valve cover.
Old 04-26-2004, 11:15 PM
C_Rock77's Avatar
PMP Designs (The company that did the red-top in the pic) LASER-cuts their valvecovers. By far, it's the cleanest cut you can get. It's pricey, though. They charge like $75 just to cut the cover (not including shipping). Friend of mine had one, and it was NIIIICE. The F*CKER sold it w/o saying ANYTHING to me . I'm not too happy about that, since he had to have known I'd be interested in it. Anyway.....the moon-cuts are the best way to go, if you don't mind shelling out the cash to have it done. I'm sure a machine shop would do it for considerably less than PMP charges.
Old 04-26-2004, 11:25 PM
xplanetearth420x's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (C_Rock77)
ya just take it to a shop or just try to do it yourself
Old 04-28-2004, 08:43 PM
dfoxengr's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (xplanetearth420x)
hole saw
Old 04-29-2004, 04:45 AM
sohc_boy's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">hole saw </TD></TR></TABLE>
Old 04-29-2004, 07:13 AM
4DRPIMPIN's Avatar
What are you going to use for your pilot hole??
Old 04-29-2004, 09:46 AM
dfoxengr's Avatar
Default Re: How do you have the valve cover so you can adjust the cam gears (4DRPIMPIN)
you dont have to have a pilot hole to use a hole saw. plus i have a drill press.
Old 04-29-2004, 10:41 AM
eyeamvic's Avatar
I just bought a temporary valve cover that was already cut. It just had the side completely cut off. And with the valve cover I took off, I'm going to have it moon cut and powder-coated. After that I can just sell off the cut valve cover.
Suck my DX
05-27-2005 06:19 PM
max8455
11-15-2004 10:15 AM
Weel
03-17-2004 05:01 PM
b20ek
15
06-17-2003 08:54 PM
Scary1109
12-15-2001 10:00 AM
Quick Reply: How do you have the valve cover so you can adjust the cam gears
