Denso Iridium IK 24's
Old 04-21-2004, 04:33 AM
MrCrx's Avatar
Default Denso Iridium IK 24's
Are these the correct heat range to run for 500whp or 20-22lbs on c16. Are these plugs worth it or should I go back to a reg NGK plug. If so what would be the part number. thanks in advance. rob
Old 04-21-2004, 05:12 AM
turbotypeR@SPEC's Avatar
Default Re: Denso Iridium IK 24's (MrCrx)
DO NOT run iridium plugs in a high hp turbo car! the iridium part will come off in the combustion chamber
Old 04-21-2004, 05:40 AM
MrCrx's Avatar
Default Re: Denso Iridium IK 24's (turbotypeR)
So what should I run then? Im going back to the dyno for some race gas tunning and want to have the right plugs in the motor. rob
Old 04-21-2004, 07:25 AM
CRX T-Si's Avatar
regular NGK's are best.
Old 04-21-2004, 08:49 AM
MrCrx's Avatar
Default Re: Denso Iridium IK 24's (CRX T-Si)
How about an NGK R5671A-10 ?
Old 04-22-2004, 12:40 AM
turb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT run iridium plugs in a high hp turbo car! the iridium part will come off in the combustion chamber</TD></TR></TABLE>
are they good up to 200whp?
Old 04-22-2004, 07:20 AM
earl's Avatar
Default Re: Denso Iridium IK 24's (turb)
Jojo runs the IK 31's with no problems
Old 04-22-2004, 07:23 AM
PrecisionH23a's Avatar
I am a fan of the ngk 3330's.
Old 04-30-2004, 11:34 AM
93LSivic's Avatar
Default Re: Denso Iridium IK 24's (PrecisionH23a)
So, did you end up using the Denso's? Did they work out for you? Im considering these plugs as well.
Old 04-30-2004, 11:39 AM
Rtype16's Avatar
Default Re: Denso Iridium IK 24's (93LSivic)
Really don't use Iridium denso plugs, huh we have them in the Pro FWD Hatchback(650hp), Pro FWD Coupe(850-900hp) and the Pro RWD Coupe(1400+hp). They all work great with these plugs never had a problem.
Old 04-30-2004, 11:53 AM
93LSivic's Avatar
Default Re: Denso Iridium IK 24's (Rtype16)
Yeah I know. We have them (same plug actually, the IK24) in our 800+ supra. Bullish recommended these plugs at the time when the car was being dyno'd. I love how bad info gets spread around
OneCrzySetup
11-17-2006 11:53 AM
josephshark
10
12-15-2005 01:39 PM
PrecisionH23a
09-29-2004 08:22 AM
LSVTEC 91 Civic
05-16-2004 04:24 PM
rice4life
04-29-2002 10:20 PM
Quick Reply: Denso Iridium IK 24's
