TPS sensor wiring...
Old 03-21-2004, 10:16 PM
*Boostwerks*'s Avatar
Default TPS sensor wiring...
Can anyone tell me which wire corrisponds to what function?
I'm wiring up my harness to my BBk mustang TB, and need to know what wire is which.
Thanks!
Bryson
Old 03-22-2004, 09:34 AM
anyone?
red wire - ?
Green wire - ?
Yellow wire - ?
Old 03-22-2004, 09:57 AM
virginia_dude's Avatar
Default Re: (Bryson)
well mathmaticly there are 9 combinations......................................
Old 03-22-2004, 10:08 AM
crx_88_si's Avatar
don't know if this helps.. ecu pinouts...
red/blue = c7
yel/wht = c13
grn/wht = c12
Old 03-22-2004, 10:09 AM
That is true...however, only 1 combination will work for me.
Old 03-23-2004, 06:41 PM
up
Old 03-23-2004, 07:51 PM
Kasper.'s Avatar
Well is that the order they appear in on the connector?
If so Id say Green is Voltage reference, Yellow is signal return, and red is your power wire.
Green and yellow could be switched around this is totally a hunch but thats just what Im thinking from what I remember on most 3 wire sensors from good ol tech school.
this is as far as which wire goes where in the connecter on average.
Old 03-23-2004, 08:11 PM
sloweredcivic's Avatar
personally i am not sure of there funtion but if you have your old tb use a multi meter to check the resistence between the pins 1-2 2-3 1-3 write them down do the same thing to your new one and hook them up to wich ever is the closest should be wortha try
Old 03-24-2004, 03:39 AM
Xsi
Xsi's Avatar
The Green one is a ground
The yellow one is constant 5V
The red one fluctuates between 0 and 5V depending on how open or closed the throttle is
http://www.integra.orcon.net.nz/tps
Old 03-24-2004, 07:53 AM
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">The Green one is a ground
http://www.integra.orcon.net.nz/tps</TD></TR></TABLE>
Thank you very much sir!
Old 03-24-2004, 02:15 PM
Kasper.'s Avatar
Wow I was way off, I guess that its a good thing they put this stuff in shop manuals....lol or Id have some very unhappy customers.
Old 02-24-2005, 10:45 AM
SiRLudeVtec's Avatar
Default Re: TPS sensor wiring... (Bryson)
actually the green is ground
aznryd3r
11-24-2006 10:05 AM
Xemu
16
11-01-2006 04:30 PM
MonkeyMagic
Audio / Security / Video
01-29-2003 06:02 PM
T25 civic
10-06-2002 02:11 PM
Quick Reply: TPS sensor wiring...
