> Honda Accord (1990 - 2002)
Old 02-27-2004, 10:08 PM   #1
Nhilcrest
Nhilcrest's Avatar
Default Repack Wheel Bearings
I have read a lot of people replacing there wheel bearings, and I am replacing the rotors on my 94 lx and had to remove the bearing so I figure I might as well clean the bearing out and regrease them. I have no reason to believe that they are bad. Does anyone see a problem with this?
Nhilcrest is offline   Reply With Quote
Old 02-27-2004, 10:14 PM   #2
InjectedPerformance
We sell parts.
Send a message via AIM to InjectedPerformance
Default Re: Repack Wheel Bearings (Nhilcrest)
Well if they have never been replaced, i would replace them. No sense in doing a job 2x. If they have been replaced in the car's life i would not change them.
InjectedPerformance is offline   Reply With Quote
Old 02-27-2004, 10:17 PM   #3
InjectedPerformance
We sell parts.
Default Re: Repack Wheel Bearings (primo8998)
Also, spin the bearings. Do they make anykind of friction noise? If they do no re-packing of grease will help.
Old 02-28-2004, 08:03 AM   #4
BVH
BVH's Avatar
They are sealed bearings you can't re-pack them.
BVH is offline   Reply With Quote
Old 02-28-2004, 08:13 AM   #5
BoostedH23Accord
BoostedH23Accord's Avatar
Default Re: Repack Wheel Bearings (BVH)
Took the words right out of my mouth.
H23/F22B Hybrid Accord Member 001
http://www.honda-tech.com/zero...ge=22
BoostedH23Accord is offline   Reply With Quote
Old 02-29-2004, 08:20 AM   #6
mwkirchner
mwkirchner's Avatar
Send a message via AIM to mwkirchner
This is absolutely true. You can NOT repack them.
Lian-Li PC-60 w/side window, EPOX 8RDA+, Amd Athlon 2400+ XP CPU (2.0 ghz) @ Athlon 2700+ XP 2.17 ghz, Mushkin PC3200 1024 MB DDR RAM, Antec SL400 400 Watt PSU, Lite-On 16x48x DVD, LG 52x24x52 CD-RW, Maxtor 40GB ATA100 hard drive, Maxtor 20GB ATA100 hard drive, PNY nVIDIA Ti4200 128 meg video card, Turtle Beach Santa Cruz sound card, USB AT ProII Media Card reader, USB 2.0 Pci card, Lian-Li dual temperature gauges, Windows XP Professional
mwkirchner is offline   Reply With Quote
Old 11-19-2009, 06:25 AM   #7
01silverstreak
well that just answered my question....
01silverstreak is offline   Reply With Quote
Old 11-19-2009, 09:20 AM   #8
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Yup, they're not service-able. You'd have to get a new set.
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 04-09-2011, 09:02 PM   #9
dhartley77
how about the rear wheel bearings
dhartley77 is offline   Reply With Quote
Old 04-10-2011, 09:39 AM   #10
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
^^ Same goes with the rear wheel bearing.
- 204whp/157wtq
Old 04-10-2011, 11:33 AM   #11
phootbag
phootbag's Avatar
I'm sorry but you guys are incorrect. You can pop the inner races out of a sealed bearing, clean and regrease the bearings and pop the inner races back in. The cage inside the bearing is plastic and can flex. This allows the races to be popped out without damaging anything. It's tricky, and you CAN damage the bearing assembly when doing this.
Though, there is no reason to do this. Since it's a sealed bearing, if the bearing is good, so is the grease. The only time this would be considered practical is if you are separating the hub for some reason and the inner race comes out with the hub. You can put the bearing back together without a problem assuming the bearing cage is still plyable. Other than that, I'd just leave the bearing alone.
Originally Posted by phootbag View Post
A "dizzy" is that magical thing you replace when your car wont start.
Originally Posted by chrisff521 View Post
Ok so youre saying I should replace the whole "dizzy" ?
phootbag is offline   Reply With Quote
Old 04-10-2011, 12:23 PM   #12
hondamark35
2000 Honda Civic
hondamark35's Avatar
true. as long as the grease hasn't become contaminated it can just be reassembled and reinstalled. care must be taken with the ball and cage assemblies. the cages are flexible but if too much force is used and they break the bearing is toast. also if the inboard set and outboard set were to be mismatched upon reassembly it could ruin the pre-load and destroy the bearing.
Currently on forum hiatus. build updates can be found here-> Build/Project Blog I can still be reached by PM.
hondamark35 is offline   Reply With Quote
2002, 94, accord, acura, bearings, civic, grease, honda, pack, repack, repacked, repacking, sealed, video, wheel
