how do i wire something up to a fuse box
Old 09-13-2001, 02:21 PM
95gsr's Avatar
Default how do i wire something up to a fuse box
how do i do this i have tried but with no luck plz help.
Old 09-13-2001, 02:45 PM
H23 Power's Avatar
Default Re: how do i wire something up to a fuse box (95gsr)
i just insert the wire into one end of the fust holder, and stick the fuse in on top of it...
BUT who knows if this is good or not its just how i do it
Old 09-13-2001, 03:28 PM
acuraintegraman's Avatar
Default Re: how do i wire something up to a fuse box (01GSR)
you can buy this adapter thing at pep boys or other local auto parts store. basically, you take out an existing fuse, insert the adapter and it has slots for 2 fuses. i did this to hard wire a radar to my car w/out splicing
Old 09-13-2001, 03:46 PM
Flamenco-T's Avatar
Default Re: how do i wire something up to a fuse box (acuraintegraman)
it's fine, I ran in like this for all my power source for sometimes now...
same difference....
Old 09-13-2001, 09:22 PM
X2BOARD's Avatar
Default Re: how do i wire something up to a fuse box (flamenco)
Get the fuse splicer as mentioned above (under $3.00 at an autoparts store) ... it plugs into an existing fuse and provides 2 fuses on the other end ... 1 for the stock fuse location and a 2nd to the new wire that you are adding with a lead wire which you can connect your stuff to... it's the cleanest way to do it...
You can also just remove the desired fuse, wrap a wire around one of the fuse blades (ensuring the wire ONLY touches ONE of the blades) and re-insert the fuse.... this is more of a rig, but if done properly, it is easy, cheep and works. The only downside to this method is that you will need to use a high gauge (thinner) wire so it will fit 14 + gauge...
Old 09-18-2001, 09:25 AM
95gsr's Avatar
Thanks i am planning on doing the radar
Luis
I Love My 4 door
12-19-2010 04:05 PM
emooheo
Audio / Security / Video
11
10-06-2010 05:53 AM
edwinbaby
09-07-2010 02:08 PM
DIRTYsouthBB6
05-03-2006 07:42 PM
superfuji57
07-30-2004 12:02 AM
Quick Reply: how do i wire something up to a fuse box
