do i need to grease anything when replacing release bearing and clutch?
Old 06-19-2003, 09:35 PM
crx1856's Avatar
Default do i need to grease anything when replacing release bearing and clutch?
as title states.
Old 06-19-2003, 10:07 PM
sporkcrx's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (crx1856)
If I remember right, you grease the inside of the pilot bearings and the shaft coming out of the transmission.
Old 06-19-2003, 10:38 PM
Moe
Moe's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (sporkcrx)
Yes you need to grease the imput shaft, where the release bearing slides on, the inside of the release bearing, take the throw out fork out, and becareful theres a small ball you dont want to lose that.
Grease where the fork touches the throw out bearing, and where the ball pivots on the fork. Thats what i did, anything that moved got greased.
http://www.c-speedracing.com has a clutch install on their site.
Old 06-20-2003, 08:34 AM
drumking15's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (Moe)
to a kid who knows where to grease!!!
Old 06-20-2003, 08:42 AM
94CivicSi's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (drumking15)
don't forget the little ball on the end of the slave cylinder.
Pbanto
04-08-2009 05:07 AM
spens 91 Ef
29
03-08-2009 08:15 AM
litterbox
14
07-20-2005 11:33 AM
JFG Kevin
06-23-2005 01:44 PM
Wes V
22
10-25-2003 12:51 PM
Quick Reply: do i need to grease anything when replacing release bearing and clutch?
