OE motor mounts
OE motor mounts
i want to get OE motor mounts. im thinking about Westar or Anchor. i watched anchors video where the mount held up under 2300lbs of pressure. price is about the same warranty is the same.
any horror stories?
any good personal expirences?
im looking to get all 4 mounts (3 engine 1 trans) and i want them all to match mfgs.
DEA doesnt have much info. im assuming Honda requires mounts to hold under 1200lbs of pressure or maybe industry standard
any horror stories?
Re: OE motor mounts
OE=Original Equipment where Hasport etc would be custom mounts right?
OEM= OE Manufacturer Honda, Toyota, DODGE, Ford etc
Re: OE motor mounts
I bought anchor the other day the quality looked pretty poor and read some reviews on how they give out over a few months so ppl would have to change em out every once and a while since they had lifetime warranty. Took them back.
He knows where you live!
Re: OE motor mounts
yeah in store prices are quite high. rockauto has them for $110 ish shipped for all 4 LMAO. i watched a youtube vid on the rear mount looks kinda difficult
OE (Original Equipment or Genuine BMW)
These are the parts that you get EXACTLY as if you are walking up to an authorized dealership and buying a part at the parts counter. (Example: Oxygen Sensor BMW Part # 11 78 1 735 499). These parts usually come in BMW marked packaging.
OEM (Original Equipment Manufacturer)
OEM parts are parts that come from the same factory that makes your Original BMW parts, but they are boxed in their respective brands. (Example: Oxygen Sensor BOSCH Part #13231, which cross references to: BMW Part # 11 78 1 735 499). These parts are sold directly from the manufacturer to the suppliers or retailers and not through the BMW Dealer network, and usually means savings for the end consumer while still having the same OEM standards that the vehicle manufacturer specified.
Anchor and Westar are not to my knowledge the OEM's for Honda.
Re: OE motor mounts
http://www.bimmerzone.com/category/T...ricks_OEM.html
You are referring to aftermarket parts. Hasport would be 'aftermarket' or third-party as well.
Re: OE motor mounts
I was hoping to avoid $200 dollar mounts but maybe not. cant seem to dodge them
Re: OE motor mounts
just got back for Camp Crystal Lake (oooo the Horror)
guess the only option Everyone agrees on is.....
Poly inserts. LOL. sound like a PITA but $600 for 4 mounts
and still no trans mount or side mount insert
Re: OE motor mounts
I've purchased from majestic honda before everything was okay but three tube seals ibought from them gave out after like 1month and got oil in all my spark plug tubes. Pita. Just being paranoid bt if they're a legit honda dealership why so much cheaper?
Re: OE motor mounts
Anything you purchase from Majestic should come in an OEM Honda package with an OEM Honda part number. Generally, if you're purchasing smaller items you're better buying them local, Majestic adds on a processing/packaging fee that can make those little clips pricey.
Re: OE motor mounts
I see.. Makes sense tho. Already placed order with my dealership only 14$ more than majestic. I'll probably order from majestic next tho just to re try them out.
Re: OE motor mounts
fordfocusforum says only use OEM (motorcraft) @ $115
mustangforum says poly insert (Energy suspension or Prothane) and in fact the Anchor mount had a few engines sitting so low they caused major engine damage which anchor wouldn't even acknowledge they just refered them to the store for lifetime warranty exchange
nissanforum says poly insert (ES or Prothane)
saturn forum says OEM (GM) no frowny face mount =(
Honda OEM mounts from Majestic are around $600 for all 4 or polyurethane front and rear mount and OEM side and trans mount for around $300
decisions decisions
Re: OE motor mounts
Hi,
We carry a few different brands of motor mounts for the Honda Accord.
All motor mounts come with a one year warranty.
Here is the link for the mounts:
AutohausAZ - Motor mounts
Disclaimer: Make sure to verify the year and model of the vehicle to make
sure proper fitment.
D16SohcVtec
08-12-2008 08:03 AM
Bbasso
03-04-2005 05:48 PM
