Need help 2002 si replace fuel pump
I think I need to replace the fuel pump. the car started last night but was running bad I tried to rev it and it died. it would start for a second then die and now it won't start at all. Can any body help? Do I need to take out the fuel cell to replace the fuel pump?
Re: Need help 2002 si replace fuel pump
Do you hear your fuel pump kick on? If it's stock it'll be very faint but you should hear it when you first turn the key on. I only know for sure on 92-00 Civics but your pump should be under the rear seat.
NovaRex
12-04-2015 05:10 PM
ill phil
04-23-2003 11:58 PM
