Built ls-vtec idle issue
Old 03-20-2014, 06:05 PM
LstecEk's Avatar
Default Built ls-vtec idle issue
Im going to post my mod list and then my issue that im having.
Please read!
B18B1
B16A2 Head
Darton sleeves 84mm
Je Turbo Pistons 9:1
Eagle rods
Z10 girldle
Stock re-built head
Stock B16 cams
GE Adj. Timing gears
Phearable Ecu
Rywire harness
Edlebrock victor x intake
Aem fuel rail
Aem 320 fuel pump
Aem afpr
Stock Injectors
Skunk t/b no FITV
New iacv
The first start of the day it cranks for a second and then starts up, i have to hold the idle around 1000rpms for atleast 1 minute before itll idle on its own. Then it idles around 950rpms. Itll idle fine until you get in and drive a few feet push the clutch in and then it has a "cam like" sometimes dying out if you dont hold it at a steady rpm.
My engine timing is dead on.
Old 03-20-2014, 06:12 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Built ls-vtec idle issue
What do you have your fuel pressure set to? Did you have the car tuned, or just basemapped? How did you set base idle, or have you not been able to yet? Is the CEL on?
Old 03-21-2014, 10:28 AM
LstecEk's Avatar
I have it set to 50psi at idle, its a basemap from phearable. And im kind of unsure how to set the base idle. And no cel.
Old 03-21-2014, 12:39 PM
NotARaCist's Avatar
Problem #1: Your base fuel pressure is set too high. Stock is 42.5 - set it to that.
Problem #2: You're running a basemap. Get your car actually tuned.
Problem #3: Base idle. There's a how-to in the FAQ's sticky, give it a read.
Old 03-21-2014, 03:00 PM
LstecEk's Avatar
Okay thanks man
Spoolinb18c
Engine Management and Tuning
01-26-2018 02:03 PM
1_bad_b18_acura
04-12-2009 04:52 PM
BKKloppenborg
09-04-2008 03:22 PM
BoostedD15B7
11-12-2003 05:53 PM
Integra_Boi
06-08-2003 07:35 PM
Quick Reply: Built ls-vtec idle issue
